Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 10-27-2015, 10:05 AM   #1
71swb4x4
71swb4x4's Avatar
WIW - my 67 C30 dump
This is one of our work trucks, and I think it's time to get into something newer. I don't trust my employees driving it (it's not a work truck to me, it's my 1967 Chevy), and we could use something a little bigger and with 4x4.
Here is a little history on it:
I purchased in January 2009.
Installed hydroboost and disk brakes from a 1975 onto the truck in April 2011. All wear components were replaced including rotors, calipers, pads, tie rods, etc. It was aligned at the same time. Probably $800 or so into this.
August 2011 new hydraulic pump and tank and really got dump working well. $1,650.
October 2013 powdercoated 7 16" wheels and had 6 new Firestone TransForce tires installed and one used one on the 7th wheel.
August 2014 adjusted rear brakes, new rear brake cylinders, new rear brake studs (9/16" vs original 1/2".
Along the way it has gotten a new carb, HEI, radiator, water pump, radiator hoses, spark plugs, wires, rear lights and wiring, receiver hitch, battery, etc.
I love this truck, it drives very nice with the hydroboost. You aren't going to break any land speed records, but it will work for you. You can remove the side, the tall sides will remove leaving short sides, and they will remove up to the steel leaving you with a good portion of flat bed.
You may see buddy buckets in there, it would sell with the bench seat, not the buddy buckets.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-27-2015, 10:08 AM   #2
71swb4x4
71swb4x4's Avatar
Re: WIW - my 67 C30 dump
It has 98,000 miles on it. It's pretty solid, there is some rust, but not much. My plan was to use it for work, and someday retire it and restore it. So things were never shortcutted with the thought that we would flip this thing some day. They were done right, because it was going to be mine for a long time.
Old 10-29-2015, 11:13 AM   #3
dubds10
Stalker Nate
I'd say in $2g range max due to the rust. Duallys aren't big sellers & often found cheap. Rocker, cab corner rust...how's the mounts & floor? Anymore rust & it's going lower on the price scale.
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 11-02-2015, 09:34 AM   #4
fine69
fine69's Avatar
Its a $2000 truck in Ohio too.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
