Old 10-27-2015, 11:30 AM   #1
WarMonger
WarMonger's Avatar
black door handles
Is there a company out there that makes black door handles, or do you just take them apart and get them powdercoated?
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 10-27-2015, 11:31 AM   #2
WarMonger
WarMonger's Avatar
Re: black door handles
Outside ones
1970 C20
-_--_--_- ______
1972 K5
Old 10-27-2015, 12:05 PM   #3
hugger6933
Just have them power coated. Idk of any being made in black
hugger6933 is offline   Reply With Quote
Old 10-27-2015, 12:09 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
If you try to take them apart the pot metal will probably break. If it doesn't break when you take it apart it will break when you try to put it back together. I would just sandblast them and paint them.
LockDoc
Leon
Old 10-27-2015, 12:40 PM   #5
WarMonger
WarMonger's Avatar
LockDoc
tha'ts what I was thinking too. Also, the powdercoat is so thick, I was worried about the thumb/push button not working.
1970 C20
-_--_--_- ______
1972 K5
Old 10-27-2015, 01:25 PM   #6
Fitz
No need to take them apart disassemble them or sandblast them if you powder coat them yourself. I haven't done that on my truck but I did it on this little riceburner I've been playing with. It started out as an ugly white four cylinder but then it grew up! Door handles and locks work just fine.
Fitz is offline   Reply With Quote
Old 10-27-2015, 02:04 PM   #7
WarMonger
WarMonger's Avatar
I do my own powdercoating, but I was worried about the internals being able to handle the heat? Any plastic parts in those?
1970 C20
-_--_--_- ______
1972 K5
Old 10-27-2015, 02:39 PM   #8
LockDoc
LockDoc's Avatar
The only thing it might affect on the truck handle is the spring inside the push button. I would try a junker first and see what it does....
LockDoc
Leon
Old 10-27-2015, 07:07 PM   #9
Fitz
No plastic, just pot metal. Cure temp is too low to affect the springs.
Old 10-28-2015, 09:56 AM   #10
midniteblues
midniteblues's Avatar
We did a set for the kids truck but they turned out like crap and we didn't use anyway.
Ours had very small pits starting so we sanded them smooth.but every spot where a pit was bubbled when pc'd and looked terrible.
They did work fine though afterwards.
My suggestion is either do perfect originals or new ones.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 10-28-2015, 10:28 AM   #11
WarMonger
WarMonger's Avatar
Thanks for the advice guys. I will try to get a new set of chrome ones and give them a coat
1970 C20
-_--_--_- ______
1972 K5
Old 10-31-2015, 09:16 AM   #12
Daman
If you do your own powder coating check out the black chrome powder from prismatic powders.
Daman is offline   Reply With Quote
Old 10-31-2015, 02:48 PM   #13
Redline novdog
Redline novdog's Avatar
I'm in. Want to hear if new handles will take the heat! I tried a set of license plate brackets and they drooped bad. I would take apart first the inside parts.
don't need to be 'coated.
If possible. Think of the Candies you could put over the chrome!!!
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 10-31-2015, 04:31 PM   #14
Shaky
Six in a row makes it go...
Shaky's Avatar
I wish I had a better picture, but I had my outside and inside handles powder coated on my '66 C10. They work fine.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 10-31-2015, 06:54 PM   #15
Spartan
Spartan's Avatar
I like you idea in theory as a theme....
I was thinking about doing a "black-chrome".
Theres a semi-rare bicycle called Austro-Diamler. The parent company was a partnership between Puch and Steyer (sp?) of germany. Steyer made a bunch of military stuff...long story short they black chromed the reynolds 531 tubing of they day and it looks really slick (to me anyways) its almost like a combination of blueing on guns and color change paint but looks mostly black-chrome.
If only I could figure out how Steyer did it...
That being said all of the chrome on the truck would have to undergo this process and theres probably a reason I have never seen this process on anything other than that specific bicycle from the late 70's to mid 80's...
cheers
spartan
'69 K20 350/4 speed/Rockwell/D44/HO52.
"orange rhymes with door hinge"
Spartan is offline   Reply With Quote
Old 10-31-2015, 07:03 PM   #16
Redline novdog
Nice look Shaky. Sparten sounds like smoke chrome.Just guessing and the color sounds awesome!
