Old 10-27-2015, 05:18 PM   #1
NC_John
NC_John's Avatar
Re: CPP's Master cylinder MCPV-1
CPP - worst customer service ever..... Find another vendor.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 10-27-2015, 05:34 PM   #2
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Thanks for the heads up on the bad service from CPP. I have read threads about that and am aware and would still like to know if anyone has used one of these Masters Cylinders.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 10-28-2015, 01:29 PM   #3
Fitz
I installed my CPP master in 2006...10 years and 15,000 miles later it is still stopping my truck without any problems.
Fitz is offline   Reply With Quote
Old 10-28-2015, 09:03 PM   #4
Z10
Z10's Avatar
I didn't purchase the set up you are looking at, but I do have experience with this set up.http://www.classicperform.com/Store/...ck/6772BBD.htm
1. The first set up had the wrong firewall bracket and booster.....returned.
2. Second set up...booster leaked and the master leaked.....returned.
3. Third set up, I gave up on the Master and purchased Wildwood. Still using the booster but... the check valve leaks and the booster leaks. I replace the check valve and that helped. I will not mess with another booster, I'll replace with anyone's else.
Also, I purchased a steering column. Bad wiring had to repair.
Also, purchased a panhard bar. Had to cut it apart and increase the bend radius to allow the diff cover to be removed, then weld and paint.
Now to be fair, the rag joint that I purchased actually fit.
Customer service stinks. I will never, ever, ever purchase anything from this company.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
