*Proud Member*
Differential Gears... I need some!
Hello fellahs...
i'm putting a posi rear in my truck and i need some gears... i have a set of 4.88's that came in the posi unit, but i want to go with a 4.11 or 3.73 ... any opinions out there?? also, does anyone have a set of gears to sell? (want to buy a good set of 4.88's?) ![]() |
Project92 SWB stepside
What rear are we talking about here??
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
*Proud Member*
its a GM 10 bolt rear... 8.5", i believe or 8.2"... haven't removed the ring and pinion quite yet.
Should be atleast a 8.5" 10 bolt. The 8.2" was mostly used in passenger cars.
yeller
If you are going to be running your th350 trans, then I would go with the 3.73 over 4.10 any day.
I had 4.10's and a th350...long highway trips were limited to 55-60 MPH...the rpm's were above 3000...and that was with a TALL tire! ![]() Now if you decide to go with an overdrive or gear vendors unit..then 4.10/4.11 is the way to go. One more thing, didn't your 75 come with a 12 bolt? 10 bolts weren't offered in the trucks until 80 or 81 I thought. ![]()
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
