Old 10-27-2015, 05:53 PM   #1
Tod59
Seat & Screw Question
Hi Guys,
Since I'm new here, I'll be posting LOTS of questions on a variety of topics.
This is a 2 part seat question about our '59 short fleetside:
Question #1: In the picture is the bottom of our bench seat (original red seat material was covered over), are the square "ports" some type of vent on the bottom of the seat? I've not seen anything like this before......why are they there?
Question #2: The bolts on these "ports" and in other areas of the truck look to take a special bit to remove them. What is the special bit called and where can I buy a few? Are they called "Clutch Head Screws"? Do any of our sponsors sell the bits?
Thanks,
Tod
Tod59 is offline   Reply With Quote
Old 10-27-2015, 08:51 PM   #2
lv2tri2
Re: Seat & Screw Question
Need a better picture of the bolts/screws.
lv2tri2 is offline   Reply With Quote
Old 10-27-2015, 09:39 PM   #3
Tod59
I'll try to get a closer picture tomorrow. But, do you know what the "cut-outs" on the bottom of the seat are for? Have you ever seen this before?
Old 10-27-2015, 09:47 PM   #4
Dan in Pasadena
Dan in Pasadena's Avatar
The cut outs aren't on either of two seats I've got. The stocker on my '55.2 and a second one from another TF, but I don't know which year. Maybe none of us have ever seen an original-from-the-factory seat? Or possibly an original GMC seat?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 10-27-2015, 09:58 PM   #5
Tod59
Interesting....I see Brothers Truck Parts sells the Clutch-head socket set for about $20. I'll be ordering those and taking the "flaps" off the bottom of the seat. I'll take a few pictures upon disassembly and post here.
Old 10-27-2015, 10:34 PM   #6
roger55
roger55's Avatar
My '57 seat has those too.
I can only guess but I'd say the seat bottom is sealed with the metal so mice can't get in there. The rubber with the slit in it allows the area to breathe.
They have to breathe to let out the flatulence.
roger55 is offline   Reply With Quote
Old 10-28-2015, 12:32 AM   #7
Dan in Pasadena
Originally Posted by roger55 View Post
...They have to breathe to let out the flatulence.
Whose? The mice or ours?
Roger's probably right. Maybe this was factory original. Lot of ours trucks were farm trucks. Lot of rodents on farms. How many of our trucks are really likely to have original upholstery after sixty years? That's probably why so few of us have seen this setup.
Old 10-28-2015, 01:45 PM   #8
_Ogre
_Ogre's Avatar
if they are clutch head screws, you can typically use a flat head screwdriver to remove them
i have to say; i've owned/driven tf trucks since 1973 and have never seen that treatment under the seats
not saying it isn't stock/oem, just never saw that
shop air compressor timer
Old 10-28-2015, 02:15 PM   #9
bowt1ed
My 57 original seat has them as well. R/Jim
bowt1ed is offline   Reply With Quote
Old 10-28-2015, 02:22 PM   #10
Valarius_Starchaser
Valarius_Starchaser's Avatar
I have been able to remove them with a #1 square bit BUT it made the bit and the screws unusable just switched to torques afterwards but for a full factory restoration the tools are sold and if your playing with a lot of 50s cars it may be wise to invest in one
Valarius_Starchaser is offline   Reply With Quote
Old 10-28-2015, 03:43 PM   #11
Cuttin up
Cuttin up's Avatar
you'll find those screw heads on damn near everything on gm vehicles up to around 64. Its wise to get a screw driver for them. I got one off of a snap on truck, but they are available at other places. I you use a flat head screw driver, it'll work on some but you may destroy the head on some of the rusty/stuck ones.
Cuttin up is offline   Reply With Quote
Old 10-28-2015, 04:26 PM   #12
1project2many
My '57 seat is built like this. It makes a great home for mice.
1project2many is offline   Reply With Quote
Old 10-28-2015, 07:54 PM   #13
OrrieG
OrrieG's Avatar
Welcome. They are so farts have a place to drain, other wise the seat would start to poof up over time. Most aftermarket places sell a set of 4 clutch head drivers. Proto, etc also have them for rachet drives, I just use a pair of vice grips on the shaft. If it will not unscrew it usually breaks off.
Old 10-30-2015, 08:39 PM   #14
SCHRUMGMC
SCHRUMGMC's Avatar
My truck has the same set up for the seat '59 GMC
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
