Old 05-17-2015, 05:43 PM   #1
muthstryker
muthstryker's Avatar
What hood latches did squares all come with?
Picked up an amazing hood this weekend at a swap meet here in Washington, I'm thinking its 73-76ish it doesn't have the typical hood pin latch system on it like the hood on my 78 right now does. But I can't find anything in any of the catalogs. How many different latch systems did they have?
Matt
muthstryker is offline   Reply With Quote
Old 05-17-2015, 05:50 PM   #2
J Knight
J Knight's Avatar
Re: What hood latches did squares all come with?
I did a 73-74 grille swap on my 78 GMC, I bought the hood latch and striker plate on the hood as well thinking it was needed for the swap but my 78 hood latch and striker plate was the same as 73-74.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 05-17-2015, 07:41 PM   #3
Titomars
Titomars's Avatar
Two.
Pin type = non locking hood
hook type = locking hood
The locking hood was a standard option starting in 77
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 05-17-2015, 10:50 PM   #4
KrazyRay
KrazyRay's Avatar
The locking hood has the inside hood release cable. There will be a square loop bolted on the hood.
KrazyRay is offline   Reply With Quote
Old 05-18-2015, 10:08 AM   #5
muthstryker
Originally Posted by Titomars View Post
Two.
Thanks guys! I guess the hood is newer than I had thought, It doesnt have the extra little body line on the front of the hood like my 78 currently does, its completely smooth which I thought came on the earlier models. But yes it has a square loop bolted to the hood.
Matt
Old 05-18-2015, 05:13 PM   #6
1774btcrew
1774btcrew's Avatar
It is an earlier hood if it doesn't have the raised section at the front. . It could be a 77. Or someone could have used the hood and wanted a locking hood and bolted that piece up.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 10-27-2015, 04:22 AM   #7
mcmlxix
Collector of Projects
mcmlxix's Avatar
Bringing this back up. Is it possible to add the inside hood release cable setup to a 78.
Rich
1972 K5 Blazer CST Click HERE
Old 10-27-2015, 09:57 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
Wondering too,I'm not sure,but removed what i could save from my 79K for my 78K.
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 10-27-2015, 10:32 AM   #9
1774btcrew
1774btcrew's Avatar
I am pretty sure to do this you need the whole bolt on piece off the upper core support of an inside hood release truck
Old 10-27-2015, 10:47 AM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
yes that appeared different and what holds the latch,down to the bottom of the rad
John
Old 10-27-2015, 05:24 PM   #11
mcmlxix
mcmlxix's Avatar
We need someone that has a 77-80 truck with cab mounted release cable to take some pictures to show the difference.
Rich
Old 10-27-2015, 05:27 PM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
lol I have both, just no time
John
Old 10-27-2015, 11:14 PM   #13
KrazyRay
KrazyRay's Avatar
Yes. You need a handful of parts to change it over. I have sold these packages, but the shipping is pricey with that long top bar.
