09-10-2015, 03:50 PM | #26 |
Re: LS swap exhaust set up (advice and pictures)
Now were getting somewhere
Thank you Kent & yeah the neighbors probably don't like me right now I have been down the street 2 to 3 times with just exhaust manifolds & down pipes very fun & very loud lol Definitely need wider tires 1969 Chevy C10 SWB 6.0 Vortec MAX/Corvette Cam 4L65E-R built by Dr.STEVE'S |
09-10-2015, 10:29 PM | #27 |
Yes Clyde65, I cut holes in the crossmember and welded in a short section of tubing for the exhaust to pass through. My truck is pretty low so everything is above the bottom of the frame.
I recorded my exhaust on my GoPro but i can't get the file to upload from the computer to this post. When my 12 year old gets home maybe she can help me. If I can figure out the noise file I will upload it.
Kent DRIVE IT HARD, DRIVE IT OFTEN! Short video of Black Betty & a friends 48 Panhead done by my kid. https://www.youtube.com/watch?v=8DlAdfwDQa8 |
09-10-2015, 10:44 PM | #28 |
Here is a picture of how the exhaust goes through the crossmember.
09-10-2015, 10:46 PM | #29 |
What size pipe?
09-10-2015, 10:50 PM | #30 |
All of the tubing on mine is 2 1/2"
09-10-2015, 11:11 PM | #31 |
Ok
Today I called a shop here in Houston that is well known for there work on our trucks called Dropz R US to see if they also do exhaust work & they said no but they highly recommended a shop nearby (Deer Park Mufflers) so I called them & spoke to the owner & when getting a quote on the job he down talked me having him install an H pipe or even an X pipe he said it's more money for him so if I absolutely wanted it he would do it but he thought it regulated the tone too much & that straight pipes would give me a better muscle car sound. He pretty much left me speechless so what do you guys think? When they recommended this guy I was told by Dropz R US that he has been doing this on performance & custom show trucks for more than 30 years. |
09-10-2015, 11:21 PM | #32 |
I hope this link works, this was a good excuse to do this video I have been wanting to do for a while.
Turn your speakers up loud, it begins about 12 seconds in. https://www.youtube.com/watch?v=qte7_Gjh38Q
09-11-2015, 12:51 AM | #33 | |
meowMEOWmeowMEOW
On an actual performance vehicle, especially one running a latemodel EFI motor, there is a "technical" advantage to running one. Exhaust scavenging and balancing are real things, and just like choosing the correct pipe size, it has an effect on the vehicles overall performance. Part of the problem/bias that occurs is where we draw the line of "Right, Wrong, Acceptable, Too Much, Too Little, Loud, Quiet"....these are all things defined by ones personal experience. Can you run a true dual exhaust with no h-pipe, homemade miter cut bends and used mufflers into a great sounding and great running truck? YES, cuz I did. Can you run a fully welded, mandrel bent, h-piped side exit and have it run and sound great? YES, cuz again..I did. TL;DR Either works, but one has mathematical calculatible and scientifically proven advantages. Oh, and I wouldn't use that exhaust guy...I don't like his tone. (pun intended)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
10-27-2015, 08:56 AM | #34 |
Good thread and opinions by all. I personally like Flowmasters for first Gen small blocks and Magnaflows for the LS stuff. Just my personal preference, but I've tried both and that's where I landed. As far as the length of the tailpipes, they are kinda like my socks, the older I get, the longer they get................. As far as the H pipe, going without it will give you more of a "Hotrod" sound. If you are on the fence about it, I would recommend going without it and if you don't like the sound OR feel you need more HP, have one installed as it's not that difficult to add one in. Just my .02. OBTW Fast&Low, you need to clean out your PM box, .
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
10-27-2015, 11:25 AM | #35 |
I have a Frankenstein for an exhaust system. Was a rush job to get my truck going. I have truck manifolds to 2 1/4" pipe into 3" pipe into flowmaster 44 and out the back by the tailgate and I friggin hate it!! It is way too loud inside and the drone is awful in my cab, so bad that you cannot have a conversation in the truck at certain rpms while driving on the freeway. I am going to have mine redone at some point with Camaro manifolds, 2 1/2 pipe, H pipe, and Magnaflow or dyno. just my experience.
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532 |
10-27-2015, 01:51 PM | #36 |
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop |
10-27-2015, 02:53 PM | #37 |
Here's a photo for those who haven't seen the available Hooker 73-87 LS swap exhaust system yet. It all tucks above the bottom of the frame and bolts right in when the Hooker engine brackets and transmission crossmember are used. I actually modified one of these systems and installed it with the Hooker crossmember on my 79' C20 long bed with great results, so it can be used in non-LS swap applications as well.[IMG][/IMG]
10-27-2015, 11:28 PM | #38 |
Sorry guy's for the late update.
Well I already had the 2010 Camaro exhaust manifolds so I went with 2 1/2 inch pipe no X pipe or H pipe Super 44's with chrome exhaust tips coming out right in front of the rear tires on both sides. Yes it's loud & yes I love It Thank you all for your time and opinions 1969 C10 SWB fleet side LQ9 Vortec MAX out of a 05 Chevy Silverado SS 4l65e-R by Dr Steve |
