![]() Join Date: Jul 2000
82 C10 manual to power brake conversion
Is the underdash linkage the same for manual and power brakes on an 82 C10?
The linkage was the same on the 69 C10 I converted to power, but it was totally different on my 55 Chevy sedan. (Less pedal travel and leverage with power brakes linkage.) And while I'm at it, which kits (or pieces and parts) do you guys recommend? My truck already has a proportioning valve mounted to the frame.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
![]() Join Date: Jul 2014
Re: 82 C10 manual to power brake conversion
On my 76 I converted to power brakes and I ended up using the brake pedal from an 86 as well as the rod end that screws. Into the firewall. It was perfect with my clutch. Long story short: just grab the parts from a junker and hook them up with a new booster/cylinder. I believe the "slot" where the brake pedal connects to rod is different between the two. I'm sure someone will give you a more definite answer though
Andrew 1953 3100 292 T5 1985 K5 Blazer 350 700R4 208 |
At the body shop.
I just swapped to manual brakes, the vacuum booster should come with half a push rod with female threads. If it does, I have the other half, you're welcome to have it.
" That didnt make it any newer " " Dont antique the equipment " |
Thanks for the response, and the offer. I'll let you know if I decide to convert. Pedal effort isn't too bad, and should be better with new rear brakes.
