Old 05-01-2013, 10:50 AM   #1
m455sx
m455sx's Avatar
Talking 62 Front Shocks
I need to know the best place to buy shock for the front of my 62, it is lowered in front.
1970 442 convertible
1970 Cutlass SX
1962 Chevy Stepside
2011 GMC 3500HD Crewcab SLT DRW
m455sx is offline   Reply With Quote
Old 05-01-2013, 11:12 AM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 62 Front Shocks
I’d suggest shopping for lowered shocks for a 63-85 truck which will have far more listings available. Pick whichever is your favorite. The only difference between the 60-62 front shocks and the 63-85 shocks is the steel sleeve in the upper rubber bushing. Just press the upper sleeve out of your 62 shocks and push it into the upper rubber bushing on the new shocks.
The steel sleeve is needed to keep the original 60-62 frame bracket from collapsing when tightened up. The later trucks use a shouldered stud instead to hold the correct spacing. This will give you a lot more options to pick from.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-01-2013, 12:19 PM   #3
m455sx
m455sx's Avatar
Re: 62 Front Shocks
great thanks!
1970 Cutlass SX
1962 Chevy Stepside
Old 05-01-2013, 07:32 PM   #4
boucher racing
boucher racing's Avatar
Re: 62 Front Shocks
Before you buy new shocks, measure the front shocks from eye to eye. I just went through this and found out that my shocks were the issue of bottoming out. I had 1/4" of compression travel!
I do not know how many inches I have lowered it, but it's alot.
Here is the thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=573266
Build Threads: "JED" 66 GMC C1000
http://inliners.org/ubbthreads/ubbth...1857#Post61857
"Cropwell" 66 C10
http://67-72chevytrucks.com/vboard/s...d.php?t=587639
boucher racing is offline   Reply With Quote
Old 10-30-2015, 09:21 AM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: 62 Front Shocks
Thank you
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
