10-29-2015, 10:48 PM | #1 |
how do I disconnect this
I looked up how to disconnect evap manifold line and didn't find anything.
10-29-2015, 11:16 PM | #2 |
Re: how do I disconnect this
The White Clip on the fitting, Push it in & Pull up.
10-29-2015, 11:20 PM | #3 |
It takes a little practice, watch this video around the 0:45 mark and it should help some.http://youtu.be/TZ6ZB_acC9w
10-30-2015, 12:06 AM | #4 |
Thank you Fellas, now do I plug this port?
10-30-2015, 12:11 AM | #5 |
Yes I would plug it with something. Unmetered air can cause these engines to do crazy stuff. You may be able to find a block off plate for it, that way you can remove the whole solenoid. Or fab one yourself?
10-30-2015, 03:53 AM | #6 |
EVAP solenoids are closed until power is applied to them, so unless its stuck open, you don't really need to do anything to it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
10-30-2015, 11:19 AM | #7 |
Good to know, well I'm just gonna ask all my questions here instead of starting a new thread. This question is on my 2008 GEN 4 5.3
Where do I route this breather line to? Its coming out of the valve cover. And what is this port behind the TB? |
