Old 10-30-2015, 02:29 PM   #1
68c10owner
68c10owner's Avatar
85 c10--700R4 to TH350
My trans went out last night but I can get a th350 from a friend. Besides the driveshaft, and needing a vacuum modulator line and moving the trans crossmembers what else will I need to do? Is the shift linkage the same? I know my indicator won't be correct but it isn't now anyways. Also, this is a short bed and trans is short shaft th350. I know a early chevelle driveshaft fits because I used one years ago but what else fits? Need to get this fixed to make it to work on monday.
Anthony
68c10owner is offline   Reply With Quote
Old 10-30-2015, 03:05 PM   #2
Kaysen
Re: 85 c10--700R4 to TH350
You'll also need the detent cable and dipstick with tube. Shift linkage will work.
Kaysen is offline   Reply With Quote
Old 10-30-2015, 03:18 PM   #3
68c10owner
68c10owner's Avatar
Dipstick tube is still in the trans, not sure about kick down cable but can get one. Just trying to make sure I`m not forgetting something before I start pulling things apart.
Anthony
Old 10-31-2015, 09:41 PM   #4
NJ C10 Guy
will your driveshaft work?
NJ C10 Guy is offline   Reply With Quote
Old 10-31-2015, 09:51 PM   #5
68c10owner
68c10owner's Avatar
My th350 is a short shaft so I will need a longer driveshaft
Anthony
Old 10-31-2015, 09:53 PM   #6
Jake Wade
Jake Wade's Avatar
If it is a short tail TH350, your current TH700R4 driveshaft will be too short, by about 3 inches.
Jake Wade is offline   Reply With Quote
Old 10-31-2015, 10:16 PM   #7
68c10owner
68c10owner's Avatar
That's what I was figuring as well
Anthony
