Life, Be In It.....
![]() Join Date: Oct 2003
HELP rear-end ID
I moved my truck, with not fluid in rear end. Can some help me ID it. It have 12 bolts on rear cover, but I am wondering if it is from a 67-72 truck or something else. I has been narrowed and modified externally. I am not sure whats inside, I took some pic of the differential gears.
Life, Be In It.....
Another Pic
Life, Be In It.....
another
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Look's like a 12 bolt narrowed and set-up for a 4-link set up...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Life, Be In It.....
How do I figure out what gears are in the differential.
An easy way to get a rough idea is to turn a tire 360 degrees and count how many times the gear rotates. That will be your gearing. So 4:11's should turn a little over 4 times for every turn of the tire. Mark the tire and gear with chalk ot masking tape so you know eactly where they start.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Easiest way is too count the ring gear teeth and divide that number by the number of pinion gear teeth. It is easisest since the is no cover on it.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
Formerly yellow72custom
The number of teeth are stamped on the ring gear. No need to count them. Just rotate the ring gear until you see the stampings, sometihg like 41 11 and divide the big number by the little and you will have the gear ratio.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
