Old 11-02-2015, 11:41 AM   #1
Sgtberad
Auto to manual swap help
So I have run into a problem with my 90 suburban Cummins/NV4500 swap. I can't find a hydraulic clutch pedal assembly for a square body in my area, but I have found one out of a 88 3/4 ton. Before I go to the junkyard and pull it out of the truck, will it work for my burb? I have called every yard in central Arkansas and I am running out of options.
Sgtberad is offline   Reply With Quote
Old 11-02-2015, 04:05 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Auto to manual swap help
I've seen a several NV4500's swapped in a square, but not one that used an 88-98 hydraulic clutch pedal assembly. Pretty sure that won't work.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 11-03-2015, 10:00 AM   #3
68Timber
68Timber's Avatar
Forgot to mention, I believe it's Advanced Adapters that makes a hydraulic conversion set up for manual pedals.
John
74 Honda Z50 build
