Old 11-03-2015, 12:03 PM   #1
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: New HBalancer is coming off! What did I do wrong?
That is correct 7/16 fine thread. It's the same as a SBC bolt and washer. I took one off an old engine I had but any of the aftermarket ones work.
If the balancer came off by hand, even if the snout looks "fine" it likely wore it down a few thousands. Since it relies on a interference fit (i.e. the snout is slight larger than the hole in the balancer), the Loctite and bolting it might not be enough to keep it from moving slightly. You're definitely going to have to tap it.
Good luck!
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
