So I only have 3 options for tubular control arms?
CPP, Ridetech or DJM for tubular?
I've read bad stuff about the DJM, the CPP are a little expensive for me and my pops and the Ridetechs are way too expensive. Anything else out there?
My mother is a recent cancer survivor and this truck build is for her |
Re: So I only have 3 options for tubular control arms?
Hotchkis but they are a little on the high side too
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
67-72 parts collector,…
![]() Join Date: Nov 2002
Porterbuilt would be my only choice.
Rebuild your stock arms WAY before DJM.
Yeah I was in the process of rebuilding the stock ones but the lowers look like they might have been damaged once upon a time.
The Porterbuilt arms are sexy but there's no way I'd spend $1100 on control arms.
![]() Join Date: Jan 2011
There is Michigan Metal works. Some better pricing on Summit and jegs, Classic parts, and performanceonline.com.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
I just went through this. The best option out there is the PorterBuilt stuff. I know that there is cheaper options but you get what you pay for.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
What are you wanting to achieve with the arms? Looks? Better performance? Easy adaptation to bags?
Do keep in mind, that you can purchase just the lowers from Porterbuilt. For example, if you are running a static dropped truck, you can get the lower 1" forward and keep factory uppers. This will give you more caster up front and position the wheel in the opening a little better. Just the lower with coil spring adapter would be $698. - Travis |
#8 | |
They sure do, and run $400 for the pair.
Hmmmm! Damn the CPP ones are $325. I've got to see if I can afford the extra.
What bushing type does CPP use? Poly? I recall PB's use Delrin.
Vintage Evil
I have some stock arms if you are interested in those?
![]() Join Date: Aug 2012
Michigan Metal Works makes quality arms at a great price. I know you said tubular but give them a look. The flat plate uppers are $149 pair. They will also make you tubular if you want.
Michigan Metal Works |
#14 | |
#15 | |
I'm just glad to be here!
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#16 |
Do I order them from you?
Daniel
#17 |
Daniel,
Yep, sure can. Just give me a call tomorrow, and can get it all going. 480-420-8175, 9-5 Arizona time. Thanks, Travis |
#18 |
Great talking to you, Travis. Can't wait to get those Porterbuilt arms.
#19 |
Same here, and thanks for the order!
I will keep you posted when they are on the way. |
#20 |
Diggin The SquareLife
they use stock crossshafts
#21 |
I looked at Porterbuilt stuff....Top notch stuff. I was all ready to order till i saw the shipping cost...
I passed on it.
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
#22 |
Post some pictures up when you get them please.
Thanks |
