ASE Certified Spoon Operator
Mavis, 67 K10/292
I had started a build thread a looooooooong time ago but since progress came to a grinding halt I wasn't keeping this current. I guess it got deleted... oh well.
Here's her story: bought for $1500 with a disc axle/unmatched gearing and t-case stuck in 4-hi. PO swapped the front axle but didn't match the gears, resulting in a crunchy diff and broken d-shaft. Awesome. Drove for a while then got a wild hair to start de-rusting her. About $300 in metal later she's all patched up. Right now she's just a cab and frame; getting back to it this year. I have an 88 Suburban's front axle (free parts are cool) to replace the toasted diff. Keeping stock rear axle but debating which axle to re-gear: rear is 4.10 (I think?) and front is 3.42 ratio. That's a ways down the road... and I need a right side fender. I got a GMC grille for her that came with the radiator support/wiring/everything; sold the Chevy grill a while back. The engine (292) is staying and getting bigger (0.060" overbore) and getting a 268 duration Schneider cam with Clifford intake and header. Probably going with a 600 CFM Edelbrock carb or injection if I can afford it. I'm saving (ha!) for an NV4500 trans and case to stick in here since I sold the SM420 and Rockwell t-case. Plus 5 speeds are better than 3 1/2. Other than that... not much is planned. I was hot on this for a good bit but several other projects got thrown on me so she had to go on the back burner for a long time... think it's been about 2 years now. So I'm back at it; here's hoping it gets done this decade! >>Dan
My six is bigger than your eight ![]() 67 K20 292 +.060" SM465 NP203 3.73s 86 4Runner, the daily on 31s 85 4Runner, the wheeler on 38s 92 x-cab truggy project for 2017... tons and 42s and V8 power ![]() Last edited by ks147j111928; 01-05-2010 at 12:28 AM. |
Re: Mavis, 67 K10/292
5 years later...
![]() Life got nutty, but she's still here. I found the flywheel, got a clutch and found a bellhousing... since I sold mine with the SM420 trans years ago because I had NV4500 plans. Not anymore! SM465 and NP205 (203?) from a 71 K10 are in now; also the axles are '77 K20 types. I want to get selectable hubs up front; those goofy auto hubs (or whatever) are... goofy, and I don't want them. Currently she's back inside the shop getting the engine/trans/case installed. I need to pick up some lifters, get the trans mounts and get it all bolted in. Unfortunately once the guts are in she's going back outside for the winter; my rock crawler is getting a V6 transplant this winter... or so I hope it gets done this winter. >>Dan
My six is bigger than your eight ![]() 67 K20 292 +.060" SM465 NP203 3.73s 86 4Runner, the daily on 31s 85 4Runner, the wheeler on 38s 92 x-cab truggy project for 2017... tons and 42s and V8 power ![]() |
Figured I'd post a few pics; nobody likes reading words without anything to look at...
![]() "air conditioning" ![]() usual rust... it's all gone now ![]() crusty old oily 292, but it ran like a champ even though the piston rings fell out when I took everything apart... fell out in pieces ![]() ![]() Rebuilt heart; almost ready to go in ![]() Along the way I traded the frame of the 2wd for a complete GMC front clip (not everything is pictured, I do have all the parts) ![]() Scored a 2wd for a parts truck; super-cheap... can't say no ![]() Early on when I first got her: ![]() Where she sat for a few years; yes she was covered up with a kick-ass tarp. ![]() Primed with Eastwood's stuff; I'll be going over it again with DuPont's primer soon since I have DuPont for color base. ![]() Lately I have been getting the engine and trans mounts all cleaned up to go back in; this weekend I am aiming to stab the engine. Tonight I'm hoping I can get the trans/t-case in... damn things are heavy! I forgot how heavy since I've been dinking with Toyota stuff for a few years now. Grond, my little '84 that started the whole mess: ![]() ...but the engine crapped a bearing, so... ![]() Then I scored a well set-up 85 4Runner: ![]() and picked up a few others along the way: ![]() Now the tan one is in line for a 3.4 V6 swap this winter, the blue one and magenta one are sold and I'm always looking for more. ![]()
