Old 11-05-2015, 12:49 PM   #1
revjames
Undercoat issues
Hello, after reading success stories I bought and sprayed 3m aerosol undercoating on my under cab. I had degreaser wire wheeled and sprayed with etch primer. I sprayed the undercoat 3 days ago and it is still soft and scrapes off with your fingernail. Is there a remedy can I paint something over it to make it hard?? I sprayed krylon on it and it still scraped off. Thanks
1963 c10
revjames is offline   Reply With Quote
Old 11-05-2015, 03:33 PM   #2
pimpston65
pimpston65's Avatar
Re: Undercoat issues
1963 c10
i used the truck bedliner stuff on mine, super tough!!! maybe the etch primer cause your issue. id say use a test panel without etch and see if it sticks and not come off...
pimpston65 is offline   Reply With Quote
Old 11-05-2015, 03:57 PM   #3
1963c-10
1963c-10's Avatar
I used truck bed liner also and its held up great.
Did you give the primer enough time to fully cure? Only thing I can think is it didn't dry enough causing the soft undercoating.
1964 Short bed trailer
Old 11-05-2015, 04:15 PM   #4
NVS-C10
NVS-C10's Avatar
Whatever brand undercoat you buy, get rubberized if you don't want it to stay greasy.. the only difference then with brands will be spray texture and coverage per can.
NVS-C10 is offline   Reply With Quote
