turn lights on tach goes to 0
ok, i have a sunpro tach installed. i took the white wire for the lights and ran it off of the wire providing light to the cigarette lighter and when i turn on teh lights it makes the tach go down below zero for some reason.... im really confused.
70 longbed 496/th400/Ford 9" |
THE HOT WIRE SHOULD BE HOOKED UP TO THE SWITCHED ING.
SPOT ON THE FUSE BOX.... the back light should be hooked up to the courtsy light spot on the fuse box.... |
the cigarette lighter light plugs into the slot i have shown below. i ran the wire off of the wire coming from here. to clear up any confusion. is this a bad place?
Try spinnin 4 rear tars
check your ground
![]() My friend's toyota w/ aftermarket tach was doing the exact same thing yesterday.
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
its all about the +6 inches
Where did you ground the tach at?
i grounded it to the dash where the bezel screws to the dash. is this a bad place?
also. my windshield wipers dont work now.... ????????? neither do my turn signals?
ttt anybody know?
Well, that is normally a good ground. Have you cleared up your regulator issues yet?
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Did those item's stop when you grounded the tach or sometime before...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Woot.
my tach just did that, it was because the lead from the dimmer came off...bad conection, check that before tearing things apart....
Clarkson 96 Chevy RCLB 4.3 2WD |
