11-01-2015, 07:40 PM | #1 |
A/C to non a/c firewall difference
Just looking to swap from a/c to heater only and wanted to know if there's a difference in the firewalls
11-01-2015, 07:48 PM | #2 |
Re: A/C to non a/c firewall difference
Yes, quite a bit different.
11-01-2015, 07:53 PM | #3 |
Are they major diffeerences and what are they?
11-02-2015, 08:38 PM | #4 |
I changed my cab from non-A/C to A/C a few years ago. Look at post #10 in my thread below, and you can see the major differences.
http://67-72chevytrucks.com/vboard/s...d.php?t=382711
1971 C10 Longbed, 350/TH350 |
11-03-2015, 07:28 AM | #5 |
Old member
Here is the picture of differences.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-05-2015, 04:49 PM | #6 |
I have templates I made from an old A/C dash to trace out where the duct ball housing go, if you need them.... I can't remember which size hole saw I used, but it worked great! most of the places you need to drill holes on the firewall have dimples where the evaporator housing attaches. Make sure you grab the flapper valve/spring and the vacuum diaphragm/bracket, as well as the little nylon bearing/nut/pivot that the flapper inserts into the cowl vent when you get your a/c parts, they don't make that part anymore,(at least I haven't been able to find a source for it yet)
Good Luck! Ben |
11-05-2015, 04:50 PM | #7 |
