Brakes 82 K20
Bleeding the brakes after new rotors. Brakes will stop the truck but the peddle continues to go down. All new parts except the master/booster and the flex brake lines. These will be replaced next. With the engine off I have good peddle and doesn't go down but goes down when engine is running. And am I supposed to bleed the brakes w/the engine on or off. Brake fluid level remains constant, no apparent leaks. I'm thinking diaphragm??? Thank You
Re: Brakes 82 K20
Is your Parking Brake/Brake Warning light on all the time now? I'm wondering if front brake circuit was drained enough and the pedal depressed if the Combination Proportioning valve tripped.
I'm getting ready to deal with this on my truck. My light is on all the time due to blowing out my rear line
SEMPER FORTIS U.S. NAVY 97-05 USAF 94-97 |
driving is in my blood
Re: Brakes 82 K20
Its either the master [most likely] or booster.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Brakes 82 K20
the way im reading this everything is fine with the truck off.. I have always been told to bleed with the truck off so if you haven't done that do that.. make sure you bleed the proper sequence farthest to closest. If the issue continues then I would suggest you check the vacuum and check valve on the booster if that is good then im thinking the booster is the culprit
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
