Old 11-03-2015, 01:54 AM   #1
BenjiLang
62 diesel
Has anyone done a diesel conversion on any 60-66 especially a 62? I just picked up a 62 lwb fleetside with a straight 6 and was planning on doing a 350 swap but that is fairly common and I'm thinking about swapping out for a diesel. I have a lot of body work expertise but not much mechanical at all so I'm wondering if the conversion will blow my ability and budget. Any info will be a huge help!
BenjiLang is offline   Reply With Quote
Old 11-03-2015, 02:40 AM   #2
spacedebris
Re: 62 diesel
I started putting a Cummins 5.9L (BT6) in my 60 Apache 30 Panel a while ago. Unfortunately I'm out of work so its on hold for now but here is a link to what I've done so far.
http://67-72chevytrucks.com/vboard/s...d.php?t=523009
It is taking a LOT of modification to make it fit right. I'm pushing the engine back and loosing some cab space. Lots of firewall modification. However I have seen the same conversion where the owner stretched the front out another 6 inches but that means frame and fender extensions.
However, from what I've learned so far, a BT4 Cummins would likely fit really nicely with a lot less modification. I also have heard that there is someone here that is doing a Duramax conversion. However I believe that the Duramax is even bigger than my BT6.
Hope this helps
1960 c30 Apache Panel w/ '95 cummins bt6 turbo diesel (work in progress) NOTE: due to photobucket trying to extort money my photos are temporarily unavailable. currently looking for alternative to fix issue.
spacedebris is offline   Reply With Quote
Old 11-03-2015, 03:11 AM   #3
BenjiLang
Re: 62 diesel
Thank you for the info. Although it's a little disheartening, as that sounds like much more than my ability or budget will allow, I'm glad to hear that before I go spend the money on a motor. Anyone know more about the fit of a 4bt in a C10 or any other recommendations of a diesel that doesn't require as much modification?
Old 11-03-2015, 09:22 AM   #4
RKO
Re: 62 diesel
Its not that hard to put a diesel in one
I would use a four cylinder turbo diesel
Friend built a 64 with a four four cylinder turbo Perkins. It had all kinds of power. He used an overdrive transmission to keep rpms down. He drove it to Alaska once
RKO is offline   Reply With Quote
Old 11-03-2015, 09:30 AM   #5
53Sparky
53Sparky's Avatar
Re: 62 diesel
The Isuzu 4BT1 diesel engine is a great small diesel engine and fits fairly well. I've seen it done but I don't have pics.
We'll burn that bridge when we get there
My current project: Rust Therapy 62 C10
Numbers 6:24-26
53Sparky is offline   Reply With Quote
Old 11-03-2015, 10:35 AM   #6
padresag
Re: 62 diesel
just try and keep the weight down
ron
padresag is offline   Reply With Quote
Old 11-03-2015, 11:13 AM   #7
TJ's Chevy
TJ's Chevy's Avatar
Re: 62 diesel
Seen a couple with Detroit 453T 4 cylinders. Nothing sounds quite as good as those green beasts. IMOP. lol
Old 11-03-2015, 11:24 AM   #8
padresag
Re: 62 diesel
the 453T was the quiet one. I drove my 453 for 18 years and they are the ones with the real tone. the turbo'd version quiets them down
you don't get to carry on a conversation anyone and you don't need to turn the radio on as it is not that easy to hear.
my gov was set at 2950 at when she was up there she was humming
ron
Old 11-03-2015, 12:35 PM   #9
dieseldude4bt
Re: 62 diesel
A 4BT can be done with no mods to the fire wall and can even keep the trans cross member in the stock location.
I used a high mount turbo manifold and had to mod the fire wall recess for exhaust clearance but with a different manifold it could be done with no mods.
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 11-03-2015, 01:19 PM   #10
padresag
Re: 62 diesel
so why is this guy having a problem with his crossmember under the b/housing?
http://67-72chevytrucks.com/vboard/s...d.php?t=686847
they are quite a bit smaller than a 453 detroit
ron
Old 11-03-2015, 02:20 PM   #11
dieseldude4bt
Re: 62 diesel
He is using a ford trans in his.
Old 11-03-2015, 07:34 PM   #12
mr andrerson
Re: 62 diesel
this guy is running a perkins in a 60
http://inlandempire.craigslist.org/cto/5259631875.html
mr andrerson is offline   Reply With Quote
Old 11-03-2015, 08:09 PM   #13
jdl71
jdl71's Avatar
Re: 62 diesel
I noticed both of these are missing the heater core/blower. Did it get moved inside or just not being used?
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 11-03-2015, 08:37 PM   #14
padresag
Re: 62 diesel
mine had a different style put inside but was useless as........on a bull. there was no room on the outside
ron
Old 11-03-2015, 11:03 PM   #15
dieseldude4bt
Re: 62 diesel
economy heater in side under dash. Vintage Air would also work.
Old 11-03-2015, 11:09 PM   #16
jdl71
jdl71's Avatar
Re: 62 diesel
Yeah, I wasn't thinking about the pre '64s having the economy with everything inside.
Psalm 23
64 C10
66 K20
Old 11-05-2015, 11:55 AM   #17
BenkeBird
BenkeBird's Avatar
Re: 62 diesel
I have a -62 Panel with a 6.2L GMC diesel and TH400 trans and it works great, but I did not do the swap, it was already done when I bought it from the other guy. Maybe I can take some photos this weekend of the motor-bay.
BenkeBird is offline   Reply With Quote
Old 11-05-2015, 12:35 PM   #18
dieseldude4bt
Re: 62 diesel
I would like to see them.
Old 11-06-2015, 06:50 PM   #19
BigSix
Re: 62 diesel
ron
My bellhousing is a lot bigger than a SM420 and pushed back farther and lower to move weight toward the center. When putting in a non-native drivetrain you really don't want all that weight jackhammering the front. I think you learned that lesson the hard way with that detroit installation! But you live and learn.
The best way to do it is to try to move things for ideal weight distribution. So ideally you would put things into the firewall and down instead of hanging forward - unfortunately that put my giant bellhousing into the shackle crossmember. If the original poster doesn't use a big overdrive transmission and mounts the engine/trans higher up he shouldn't run into my issue.
I recommend the 4BT - it fits well and I believe the weight is approximately the same as or a little less than the stock GMC V6.
The 6BT is a big engine - I have one of those too. I don't know if that would fit in the 60-66 bay.
With all this said - don't expect a quick swap that is straightforward. There is a good amount of fabrication, tinkering, and most of all you will get the bug to go through the engine. I went all the way down to taking out the crank...
Good luck and if you have any 4BT questions we have a few people who have them and may know the answer.
BigSix is offline   Reply With Quote
Old 11-06-2015, 08:37 PM   #20
padresag
Re: 62 diesel
i have already told you that was not a sm420 that was in mine .tI told you what it was and it is a little heavier duty and bigger than what you have (a 5 speed o/d). mine also had a 13" clutch which does require a larger bellhousing. the bellhousing mounted in the same area as a stock one would have been, so the trans would have hung in the right place.
I didn't have anything to live and learn about. the detroit was mounted in there where it should have been . it could not have been moved back nor could it have been moved forward, just that it was heavy . it handled and performed well
ron
Old 11-06-2015, 10:32 PM   #21
BigSix
Re: 62 diesel
ron
I know. But just above you asked why I had trouble with my bellhousing and I explained my transmission is bigger than the stock SM420 and mounted differently. I seem to have made you sensitive about your old setup - did not mean to. Just wanted to answer your above question because you had posted a link which made me think I didn't clarify originally. Also giving some shoehorning advice to the original poster
Old 11-09-2015, 12:53 PM   #22
BenkeBird
BenkeBird's Avatar
Re: 62 diesel
Here is the picture tha a take this weekend, maybe it will help you, that was tricky to take the picture in details so I took two of the engine bay and one of the motor mount on the left side.
Old 11-24-2015, 04:55 PM   #23
TJ's Chevy
TJ's Chevy's Avatar
Re: 62 diesel
Man that 6.2 fits in nicely. Might have to consider one for the future. I've heard that a turbo wakes these things up nicely.
Old 11-24-2015, 10:26 PM   #24
dieseldude4bt
Re: 62 diesel
What kind of mileage do you get with that 6.2 diesel?
Old 11-25-2015, 08:40 PM   #25
BigSix
Re: 62 diesel
That 6.2 looks mighty fine. I really like that. Around here all the postal bread trucks are 6.2 and have crazy mileage on them - seem to be tight engines that do not share the 6.5 reputation.
