Old 11-06-2015, 11:40 PM   #51
DblTrbl
DblTrbl's Avatar
Re: My 83' Crew Cab Dually project
Originally Posted by travlinman View Post
I'll take the notch and 4 link off ur hands lol . What size did u order? Wanna come do mine too?I'm starting to get tired of staring at it at stock height lol
4x3 1/4 wall. It's not cheap. The plated step I have now was considerably less.
Buy me a plane ticket when it gets unbearably cold and I'm buried in 2ft of snow. I'll come build yours in the sunshine.
DblTrbl is offline   Reply With Quote
Old 11-07-2015, 07:14 PM   #52
travlinman
For a plane ticket and material cost that's something I'd really consider to finally get my truck on the ground lol. Not sure what u would do in this 65deg winter weather in CA lol
94 ls swap silverado
65 Pontiac
78 c30 crew cab dually (parted and gone)
82 c30 crew cab dually ( now building )
91 r30 crew cab dually (parted and gone)
69 swb-sold
71 lab sold
all in progress......__
..........._______ |__\__
..........|__(O)______(O)] ........................
travlinman is offline   Reply With Quote
Old 11-07-2015, 07:46 PM   #53
DblTrbl
DblTrbl's Avatar
Took a break from the truck today to build a welding table. No more welding on the floor! Plus, now I'll be set when I start tig welding the smaller bits.
Old 11-08-2015, 05:31 PM   #54
DblTrbl
DblTrbl's Avatar
Planning out my new notch with consideration for the SFBD. Keeping in mind that I'll have 4" from the inside of the top of the frame, I can see that my rear frame is going to actually be hanging 2" lower than stock if I run a straight rail from the front. This seems like the simplest method. It is, however, going to make my frame nearly 10" tall behind the cab.
Old 11-08-2015, 11:03 PM   #55
SCOTI
SCOTI's Avatar
Ok..... SFBD's happen diff ways. What is your approach going to be?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-09-2015, 12:43 AM   #56
DblTrbl
DblTrbl's Avatar
3x4 in the top of the rails under the cab tied into a Z up front. Very similar to what Dool Eh did, but not quite as radical.
Old 11-09-2015, 12:45 AM   #57
SCOTI
SCOTI's Avatar
Gotcha.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-09-2015, 09:08 AM   #58
dragnframe
Originally Posted by DblTrbl View Post
Do you have a thread going or any pics of yours?
Didn't start a thread yet, mostly been collecting parts but i'm gonna go full bore starting 2016. Will start a thread then
dragnframe is offline   Reply With Quote
Old 11-14-2015, 08:00 PM   #59
DblTrbl
DblTrbl's Avatar
Finally had some time to get back at this thing after putting in over 60hrs at work this week...
Got most of my material cut:
Started burning the new notch together:
Old 11-15-2015, 07:28 PM   #60
DblTrbl
DblTrbl's Avatar
**** you, old notch!
Old 11-15-2015, 10:23 PM   #61
DblTrbl
DblTrbl's Avatar
Done for today...
Old 11-16-2015, 02:21 AM   #62
travlinman
Lookin good! Now I'm really going to have to fly but out to do mine lol! What's the specs on the 4 link u ordered?
65 Pontiac
69 swb-sold
71 lab sold
Old 11-16-2015, 12:36 PM   #63
DblTrbl
DblTrbl's Avatar
It's the Thorbros "fat" kit with 36" bar length. I could have gone longer, but since I'm going bag-on-bar, I wanted to keep it shorter so I didn't have too much flex. My lower bag mounts and gussets should be coming soon, I hope.
Old 11-20-2015, 01:29 PM   #64
DblTrbl
DblTrbl's Avatar
I picked up another stick of the 3x4" steel this morning. They only had one 12' piece for me. I needed two, so I guess I'll be starting on just one side of the frame this weekend.
To those that have done the SFBD, are there any pitfalls or tips that I should be aware of before I start cutting and fitting into the midsection of the frame?
Old 11-20-2015, 01:47 PM   #65
tinydb84
tinydb84's Avatar
I ended up using one piece of 3x4x.250 and splitting it in two:
Fit it in the frame:
[/QUOTE]
I welded the top in first completely (the white paint is weldable primer, I knew I wouldn't get around to painting it for a bit and didn't want to deal with rust after I cleaned everything). Then removed 6 inch sections at a time from the bottom as I welded it in so that way I knew the frame would flex or move too much:
Then I welded in some L shaped fishplates because I am paranoid:
Take the body off if you have the space. That probably was the worst part.
David
Instagram: myfabguy
Old 11-20-2015, 02:50 PM   #66
DblTrbl
DblTrbl's Avatar
Those fishplates are a good idea. I think I'll steal that from you.
Is there a big risk of warp/flex when burning these in? It seems like the 1/4 wall tube would be pretty resistant to that.
I cant quite see from your pics; where did you end the tube at the front? Are you into the Z'd area? I'd like to tie my 12' tube right into the Z with as few joints as possible...Less joints: less movement.
Old 11-20-2015, 03:04 PM   #67
tinydb84
tinydb84's Avatar
The fishplates ended up not looking bad. I am happy I went with them. If I had welded the frame in a better position and the bead looked better I would have just let it be but I didn't like the look and had to do something.
I wasn't worried about general warping but the weight of the cab possibly flexing the frame downward like how a 2x4 sags a bit if you only support one end. Probably not necessary but didn't hurt.
I tied the Z into the front. This is probably the best pic I got:
I did the SFBD first so I could just make one plate over the top.
David
Instagram: myfabguy
Old 11-20-2015, 03:55 PM   #68
DblTrbl
DblTrbl's Avatar
This is similar to how I want to tie it in (not my truck), but I'd like to have a better joint, meaning cut to angle on both sticks vs. a square cut on one.
And I agree with how you did the Z last. That's my plan as well.
Old 11-20-2015, 04:34 PM   #69
tinydb84
tinydb84's Avatar
I forgot about that build thread. I just went back and read it for some inspiration. I wish I had the skill some of these people have.
I did my SFBD and Z when I was new to fab. I would do a few things different now but for the most part I am just building a cruiser. I'll have to step up my game when I get to my 66.
David
Instagram: myfabguy
Old 11-20-2015, 06:21 PM   #70
DblTrbl
DblTrbl's Avatar
Progress...
Got my rear squared and burned in. I need to go get some taller stands to get the whole thing up and off the floor and leveled up again before I dig into the rails under the cab.
And I melted my nozzle on the welder by forgetting to kick up the wire speed for overhead.
Old 11-22-2015, 10:14 PM   #71
DblTrbl
DblTrbl's Avatar
Started in on the rails under the cab today. Cleared all of the junk out of the way and ditched the fuel tank selector thing. I trimmed the carrier bearing crossmember using a scrap as a scribing pattern, but didn't take into consideration that the 11' piece would have more obstacles to deal with, so I still need to clearance some more to get it to sit all the way in.
Cut the lower edge of the frame off from the cab back:
Fitting the rail in place:
As it turns out, the rear cab mount is just above the rail, so I don't have to make any modifications to it. I'm pretty happy about that. Actually, all of the mounts should be able to stay in place and I can just weld the edges to make up for the rivets I had to remove.
Old 11-22-2015, 10:35 PM   #72
tinydb84
tinydb84's Avatar
Dont you love when something comes out to be easier than you thought it was going to be?
David
Instagram: myfabguy
Old 11-22-2015, 10:42 PM   #73
DblTrbl
DblTrbl's Avatar
Considering that I had to rebuild the entire step notch, it's a welcome improvement.
Old 11-23-2015, 08:53 PM   #74
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Looks good, you didn't mention you had a thread goin lol
1988 Chevy R30 Dually Crew-Cab - Build thread Cummins swap + Bagged and Bodied on Semi wheels, work in progress
Ghostwhite is offline   Reply With Quote
Old 11-24-2015, 09:48 AM   #75
DblTrbl
DblTrbl's Avatar
Haha. I thought you had already seen this. I wasn't blowing smoke with all the questions in your thread. I'm at just about the same place as you.
