panhard bar mount
Re: panhard bar mount
They vary between years. Is that a 64 you have there? Sorry, I don't know where you could get one.
you should be holding that brake line done. there should be a hold down which which attaches on the inspection cover. It could rub a hole against the panhard bar and at the p/bar bracket. looks a little sloppy
ron |
60-66 Nut
There are no factory reproduction panhard bar brackets that I know of. Do you need one for a '63-'64 or a '65-'72?
this is a pic i found online, not my truck.
i'm putting a coil spring 12 bolt in a GMC. i have everything but this bracket. i ordered an adjustable panhard bar kit for a '65 Chevrolet, so i would guess i'd need the matching frame bracket. |
| Bookmarks |
