Do I need new Axle shafts? (Pic inside)
Hey all,
I thought I had chased this wobble down with the front spindle but now I believe it is coming from my rear axle. The driver side rear axle had a small amount of play in it where I could kind of rotate it in a circle and up and down a very tiny bit. The passenger side did not do this but I pulled both as well. Does this look like I need new shafts or just bearings? ![]() Driver side ![]() Pass side ![]() Thanks for any help.
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532 |
Re: Do I need new Axle shafts? (Pic inside)
I would check the play in the bearing and then the play between the bearing and the shaft. If no play at the shaft. Your good
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
I would replace the passenger side for sure but if your buying new I would just get both less to worry about. Makes me wonder about the 12bolt in my k5 now
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. ![]() 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
Pass side bad for sure.
Both of them look bad. Repair bearings have already been used. The passenger side is the worst, but the driver's side looks like it is getting a lip as well and will need eventual replacement.
![]() Join Date: Oct 2012
Passenger side axle and bearing for sure, if it were me I would go ahead and do both sides. You're probably looking at a couple hundred bucks to get new axles, bearings and seals. If money and time is a factor, polish up the passenger shaft (you'll likely never be able to remove all of the pitting, but you can make it smoother) stick it all back together until you can round up the parts. Then get it knocked out.
Thanks for all the replies, much appreciated!! I ordered Moser axle shafts, studs, and seals. I was going to order the timkin bearings but a review on there said they were repair bearings and not what was stated so I will be buying bearings local. I will let you know how it turns out, hopefully this is the source of the wobble.
Ben
