Accuair vu4 manifold with Different controller ?
Anyone running the accuair vu4 with the avs controller or any other type of controller? I like the idea of accuair but don't like the wireless remote .
Thanks |
Re: Accuair vu4 manifold with Different controller ?
I have not done it but believe you can do it.
Squarebody guy
The standard VU4 manifold comes with a wired remote.
Yes you can wire up the manifold to seperate switches as well.
1988 Chevy R30 Dually Crew-Cab - Build thread Cummins swap + Bagged and Bodied on Semi wheels, work in progress |
Jondancer...Yes. You can run both. I have Accuair VU4 manilfold with a 7 button AVS Controller! Works great.
Yep, you can run it with a different controller and just have to cut and splice into the VU4 harness. If it's the AVS switch box, like the Arc-7, then they make a plug-n-play harness between the 2.
