Old 11-05-2015, 03:19 AM   #1
SonomaComa
Where to find complete Heater Duct replacement
I have a 1970 GMC C-20 without A/C. I have all new replacement parts for the heater system. Everything except the Duct work. I purchased them at Classic Industries. They offer 2 out of 3 parts for the Duct work. They have the Outer Heater Box from inside the Engine Compartment Part #17183 and the Air Selector Duct Assembly Part #G2776. But I can't find the piece that attaches from inside the cab to the Firewall. They only offer something called the Heater Box "S" Plenum (#AP7221) which looks nothing like what is in the truck. Listed here... http://www.classicindustries.com/sho...c-heater/?&p=9
I am looking for these 3 pieces. The very bottom piece separates into 2 pieces.
SonomaComa is offline   Reply With Quote
Old 11-05-2015, 03:48 AM   #2
F.A.A.benny
Re: Where to find complete Heater Duct replacement
The metal duct at the end isn't reproduced, I believe. I haven't seen it in any catalog
F.A.A.benny is offline   Reply With Quote
Old 11-05-2015, 04:15 AM   #3
Grumpy old man
Grumpy old man's Avatar
I have a few , EXACTLY which piece do you need ?
Old 11-05-2015, 04:23 AM   #4
SonomaComa
In the picture that I posted, it would be a piece from the bottom. The right hand side of the bottom piece. I still have mine but was going to replace all the parts listed in the picture.
I listed the parts that are available by Part Numer listed in Classic Industries catalog.
Old 11-05-2015, 04:56 AM   #5
Grumpy old man
Member DaHos has a few listed already in the parts section and his prices are cheap see if this link works
http://67-72chevytrucks.com/vboard/s...d.php?t=687442
Old 11-05-2015, 12:05 PM   #6
SonomaComa
Great, just my luck. Why is only 2 out of 3 parts of the Duct Work available?
Old 11-05-2015, 12:34 PM   #7
Grumpy old man
Let me understand ,You have all the parts ? you just want to replace them with shiny tiawanese reproductions instead of restoring what you already have ???
Old 11-06-2015, 02:32 AM   #8
SonomaComa
No reproduction parts built here in the U.S. ?
It looks like mine has been kicked a few times and dented up. I was hoping to find a new one to bolt on. Mine will take some time to rebuild and straighten out. All the doors and flaps don't work all that well right now.
Old 11-06-2015, 06:03 AM   #9
F.A.A.benny
This is how I restore them. I take them apart, bead blast, paint and I replate the door and the rod. Also install new foam. They are the same for both ac and non ac trucks but they aren't reproduced.
Old 11-06-2015, 10:38 AM   #10
SonomaComa
You replace the door and rod?
Where do you get them?
Old 11-06-2015, 01:17 PM   #11
F.A.A.benny
I didn't replace them. I removed them. Then I replated them, replaced the foam and reinstalled them.
Old 11-08-2015, 11:46 PM   #12
SonomaComa
They look awesome!
Old 11-09-2015, 01:49 AM   #13
F.A.A.benny
I can do another duct like that one for you if youre interested. I have several spares.
Old 11-09-2015, 11:18 AM   #14
SonomaComa
How much? I do not have A/C. Mine is kinda dented and don't look that good and does not have the new rubber on any of the doors or flaps.
On a heater system without A/C is a Heater Control Valve necessary? How do you stop the water from flowing through the heater core?
An don the heater core, which gets mounted on the top, the 5/8" or 3/4" pipe?
