11-09-2015, 07:12 PM | #1 |
Clean a built engine
I removed my engine and I'm looking for tips on cleaning and repainting the engine without dismantling it.
1. If I use a strong solvent do I have to worry about the intake manifold gasket, timing cover gasket or the valve cover gaskets? 2. There's some dirt that I can't remove with scrubbing, scrapping, grinding or soaking. Can I just leave these little bits and paint over them? 3. I'm using simple green on the upper half and Castrol super clean on the lower half and a gun brush to scrub the tight areas. any suggestions on cleaners or scrubbers that work well for cleaning? thanks a lot
Robert 1975 C10 - Huckleberry 2007 Jeep JK - John Wayne Jeep Smittybilt front/rear bumper, 10K winch Pacific Grove, CA |
11-09-2015, 07:40 PM | #2 |
Re: Clean a built engine
I'm sure they're some good info in the comments of this http://67-72chevytrucks.com/vboard/s...g+engine+block
I searched engine cleaning. I'm not sure of an answe for 1 and 3 but for number 2 I would remove as much as possible and anyway, it'll only make problems down the road. Depends where it's at too and if you'll see it everyday when opening the hood.
85' GMC Sierra Classic Built 350; Weiand intake, Holley 600, Thumpr Cam Built 350 turbo with shift kit & 2500 Stall Thumpin' away |
