11-10-2015, 09:03 AM | #1 |
But Found Her 25yrs Later!
88+ Parts?
I know we've concluded the frame is of no use.
Also the rear axle is like a total of 3" wider. So, Is there anything of use on the 88+ trucks besides the motor and tranny that we can use on our trucks?
11-10-2015, 11:36 AM | #2 |
Never Ending Projects
Re: 88+ Parts?
Not really.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
11-10-2015, 08:16 PM | #4 |
Re: 88+ Parts?
power steering box, brake booster, underbed fuel tanks...bout all I can think of
1961 c10 longbed - gone 1964 c10 swb |
11-10-2015, 08:52 PM | #5 |
Re: 88+ Parts?
The bench seats with the integrated seat belts are great. I think thats late 90s early 2000s though...
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE |
11-11-2015, 02:01 AM | #6 |
60-66 Nut
Re: 88+ Parts?
The steering box will not work unless it is from a '87-'91 R1500. I believe LostMy65 is talking about the '88+ full size trucks.
Yes the brake booster will work. In fact it is on the list of boosters compatible with all of my booster brackets. The master cylinder could also be used if one does not mind the look of those. As for the fuel tank, I don't know if that will fit under a '63-'72 truck. The '88+ trucks have a much wider frame which means more room between the frame and driveshaft.
