No SPID Plate, can I get some ideas on what I have here?
I bought this '70 C10? With State issued vin#. I want to figure out what if any options I have here.
The Inline 6 and 3 speed are easy for a newcomer like me to figure out. I am about to re-gasket the rear end so I will check the gear ratio when the cover is off. What other items should I be looking at? Thanks, Bill See pictures here. http://2212.ecarlist.com/web/ebay_photos/21857452/
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
#2 | |
Still plays with trucks
Re: No SPID Plate, can I get some ideas on what I have here?
It looks pretty clean in the photos. I would just do the basics like checking the condition of the steering linkage / ball joints / idler arm and check the condition of the brake shoes / wheel cylinders / axle seals plus all the fluid levels.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#3 | |
The Older Generation
Unless there is a build sheet under or behind the seat (in the springs) you are probably out of luck with no SPID. The ring and pinion tooth count chart is in post #2 in this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578793 LockDoc
Factory power steering too! I would like to see a picture of the power steering lines where they cross over the frame if you wouldn't mind. Nice truck
member #16
![]() Join Date: Dec 1999
Besides the power steering , which most six cyl's did not have you also have the optional wood bed floor, Looks like a very nice truck. The full gauge option would have been listed on the SPID.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
#6 | |
The truck is very clean! Steering is tight, Getting ready to convert to front disc brakes with new ball joints and some tie rod ends, Will inspect the rear brakes/cylinders/axles when she's in the air. Fluid levels are already checked. Thanks,
#7 | |
Thank you for the link, I read that one once before, but failed to save the link.
I will try to get a picture over the weekend of the PS lines for you.
#9 | |
I'm adding power front disc brakes to the power steering this winter to make my knees last longer!
