Re: fuel tank question
I am not sure but since it's a return line I don't think it matters as long as it goes back to the tank? Anyone else? At least in my case I just hooked the return hose from the corvette fuel filter back to the tank and wished it well. I am running stock in-cab tank also.
#2 | |
Fuel return needs to go near the bottom of the tank. You don't want a fuel spray from the top. Leads to aeration, heat, cavitation....all sorts of issues easily avoided.
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 |
#4 | |
The Older Generation
LockDoc
#5 | ||
It'll flow most when you let off.
1973 C20, 350/350 |
If the return line needs to be below the fuel surface at all times it would have to be near the bottom of the tank. I am not an engineer or even very smart, but common sense tells me that if you put a pressure gauge on a return line that is flowing freely it is not going to show any pressure. If the return line is below the surface of the fuel it may show a slight amount, and the further down in the fuel it is the more pressure it will show but still not much.... Dunno.... While we are on the subject of fuel return I see no reason that the return line couldn't be fed back into the fuel pump inlet with a tee or wye fitting. (I think a wye would be better for the flow) I was going to try this on my '67 Panel Truck but I had to buy a new fuel tank and it had a return line fitting on it. Has anyone tried this???? LockDoc
#7 | |
I do appreciate all the Info you guys have given me im going to run the return line to the bottom of the tank.
