Pronounced "Pew-al-up"
truck wont idle, carb leaking fuel
My truck wont idle on its own, and the carburator is leaking fuel out the back thru the tube in my drawing. It sounds like the truck is missing.
I had this happen once before, but I figured I just flooded it, and in the morning it fired right up. This time it didnt work. I have a newer Holley 600CFM, w/ electric choke.... Please excuse the crude drawing. HELP!!!:p
Classic GM Trucks of Washington Club Member 1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's, Power Locks, Truck Photos |
Possible Float valve is leaking or stuck open.
Classic GM Trucks of Washington Club Member 1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's, Power Locks, Truck Photos Last edited by DanoDMano; 02-21-2004 at 01:23 PM. |
The floats sometimes develop a leak, allowing gas to get inside the float so it doesn't float. When the float doesn't float, it allows the fuel to continue entering the carb bowl. Got it? If it's like most carbs, you have to pull the top off the carb to access the float. You'll want to replace the gasket when you're done. A rebuild kit normally includes everything you'll need. Jewels pulled her 2 barrel off ot rebuild it, I've done a couple on the engine (if the carb to intake gasket doesn't need to be replaced).
good luck, scott
Silence is golden, duct tape is silver. - Scott |
Its not leaking out of the carb bowl. Its coming out of the tube at the rear of the carburator???
Active Member
![]() Join Date: Jun 2002
Secondary float needle and seat are dirty or float sticking. Mine would flood out when I stopped and got progressively worse. Take the bowl off clean the needle and seat and get a good fuel filter. Mine had fine rust on it.
1969 C10 350 3spd 1995 GMC 3500 XC 350 dually When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin |
I think that tube is the bowl vent, made just for this reason.
good luck, scott
Thanks alot Guy's!! Man I'll never get over how cool this board has been. That sounds exactly like the problem with my truck.
I am going to tear into it this morning. ![]()
If I hadn't already promised to hepl rebuild my daughter's boyfriend's brakes, I'd come help.
good luck, scott
Thanks Scott!! Its always a learning experience with my truck, but I sure enjoy working on it!!
Thanks for all the help!!! ![]()
DanoDMano you might want to check the spark plugs also . To much fuel going down the intake will foul them . You might also check out the oil dip stick and see if there is a smell of gas if there is you will have to change your oil . Jose
What are you looking at?
mine was doing the same thing. I changed the Power valve and it took care of the problem. I have heard Holley's are notorious for blowing these
Greg
1971 GMC LWB 2005 Honda Element 2007 Honda Fit ![]() |
#13 | |
Just sitting here contemplating contemplation. |
Yup, it was the secondary float!!! I disassembled it and cleaned it up. Works fine now!!!
I found a real cool website in the process too!! Hotrod Info Thanks as usual!! ![]()
#15 |
not so dumb
Hey Dano, we're so as dumb as we look!!
