Old 11-07-2015, 01:35 PM   #1
scuderia
scuderia's Avatar
Pulleys 327 vs 292
Collecting parts for my 327 that will ultimately replace my tired 292. I believe that I can reuse the starter, alternator and a few other bits. I'm wondering about the pulleys for the water pump and crank? Are they the same? The 327 comes from a '68 Camaro and I'll be using short water pump if that makes any difference. Oh, and what about the fan, can I use the one from the 292? I already have the V8 size radiator... thanks
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline   Reply With Quote
Old 11-11-2015, 02:07 PM   #2
Bad4wd
Re: Pulleys 327 vs 292
Here's what I have.
Short WP. Might have to press the mounting hub up or down to get proper alignment.
Water pump pulley is GM 3905995
Crank pulleys are 3744043 double & 3751232 single for power steering.
PS bracket . 3941114 will need to cut a little with a 8''Bal.
Bad4wd is offline   Reply With Quote
Old 11-13-2015, 12:12 PM   #3
scuderia
scuderia's Avatar
Originally Posted by Bad4wd View Post
Here's what I have.
Thanks a bunch! Your motor looks and sounds amazing. Nice work.
'66 C10 SWB
'64 C2 roadster
'70 Triumph T120R
'81 Laverda Jota
