Old 11-10-2015, 10:20 PM   #1
Kaptain Kadian
Kaptain Kadian's Avatar
anyone cut the gas tank holder tabs out?
I relocated the gas tank, and am wanting to put a sub box behind the seat. Trying to figure out if it is worth the trouble to cut the mounting tabs off or just build the box around them. Thanks.
Kaptain Kadian is offline   Reply With Quote
Old 11-11-2015, 01:46 AM   #2
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Re: anyone cut the gas tank holder tabs out?
I used them to secure my box, easy to do and strong enough to keep it from rattling.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 11-11-2015, 01:16 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: anyone cut the gas tank holder tabs out?
I also used these tabs for securing my box in place.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-12-2015, 06:37 PM   #4
Kaptain Kadian
Did you guys use 1/2 in or 3/4 in mdf?
Old 11-12-2015, 08:26 PM   #5
Andy4639
Old member
Andy4639's Avatar
Mine was 3/4" and I used thin 1/4" for the backside up against the cab wall.
It's not perfect but the 10" subs will hit pretty good when I turn it up.
Old 11-13-2015, 01:53 PM   #6
kehstr
kehstr's Avatar
your tank might rusty, and all corroded inside, so if i was you, i would just avoid cutting up your tank, that can just make more problems. Especially where it's so easy to build a bracket
kehstr is offline   Reply With Quote
Old 11-13-2015, 02:55 PM   #7
Kaptain Kadian
I wasn't going to cut the tank, it is already gone. I was talking about cutting the tabs out that are in the back of the cab that the tank bolts to.
Old 11-13-2015, 03:07 PM   #8
kehstr
kehstr's Avatar
I used those tabs to hold the my subs and speakers down, which works really well, i don't know how things would work if you cut them out, so i can't help you there, sorry
