Old 11-13-2015, 06:45 PM   #11
Chad22873
Chad22873's Avatar
Re: Blazer Bed Floor Replacement
Makes sense. So if that's the case, the only real modification would be the rear sill then like you said. So the wood would then also go on top of the wheelhouse flanges? Did you use the corner strips like whats used in stepsides? Or do you think that's even necessary? Are the SS strip for a shortbed long enuf? I cant remember whether the blazer floor is longer or shorter than a shortbed. I was thinking it was longer. I look forward to the pic.
Chad22873 is offline   Reply With Quote
