Old 10-28-2015, 08:24 AM   #176
lower50's
lower50's's Avatar
Re: 49 3600, s10 swap, project boogie
Dam instructions!! The bumper and shifter look good tho.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 10-28-2015, 10:59 AM   #177
99 to Life
99 to Life's Avatar
these little things add up big time. With your ac unit there, it prolly doesn't put out much heat does it? I had one similar to that, ebay deal. wasted hours making a bracket for it yada yada, no heat. had to get a unit that was strictly for heat.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 10-29-2015, 09:31 PM   #178
joedoh
joedoh's Avatar
It cooked me the other day, so I think it will be ok. I spent a lot of time schmutzing the holes in the firewall so it is pretty sealed.
spent waaaay to much time dinking with the original dome light. the guy asked me to hook it up, I said sure. found the wire in the a pillar, hooked up 12v and checked voltage at the switch on the light, nada. cleaned up the wire, 12v on one side, not the other. cleaned up the wire on the other side, and the insulation came apart all the way inside the bulb socket. *SIGH* why do I even bother?
knocked out the old socket, drilled the hole bigger and installed a NEW socket.
hunted around for a bulb, ended up stealing the one out of the blazer. ran new pair of wires to the dome location
wired it up, this time wired it directly to the underdash dome light. before it only had a single wire to the dome because these trucks dont have door pins. but because it has them now, I just tapped the two wires into another door light and viola!
finished up the rat fink shifter too. pulled the carpet to vacuum it
the thing wiggles like a widow pleaser when the engine is running, but looks super cool
Old 11-01-2015, 07:20 PM   #179
joedoh
joedoh's Avatar
sorry for the dead image links, I advertised the truck with a link to the album and it went over in bandwidth. it will reset on the 7th, until then I will use the old account.
washy washy
beeps likes the hubcaps
cleaned up
caught a train, and then it stopped. this actually turned out as a nice picture I think
family says so long!
on its way home
now on to the 49 which the thread is named after. be nice to use these parts that have been super clogging the garage haha
Old 11-01-2015, 10:30 PM   #180
99 to Life
99 to Life's Avatar
nice pics, congrats on the sale. can't wait to see that 49' on the road.
Old 11-03-2015, 12:55 AM   #181
lower50's
lower50's's Avatar
Glad it all worked out. The anticipation for the '49 is killing me lol
1951 MG TD
Old 11-14-2015, 09:07 PM   #182
joedoh
joedoh's Avatar
no progress yet, still cleaning the garage. but almost enough room for a truck now!
its outside now and all the remodel/moving stuff is GONE. got a nice welding table off craigslist for $40
got a nice high table for a solder station too, thats whats behind it.
should be all clean and ready for the 49 tomorrow, moving the fridge to the other side of the wall and putting that 4.3 4l60e on a cart to free up my wheel dollies. tie up some hanging wires, sweep, organize tools again. its funny, I found every single small funnel I have "lost" over the years and all my tools magically fit in my tool box.
Old 11-16-2015, 02:11 PM   #183
lower50's
lower50's's Avatar
It's always fun to clean up the shop when the project is out.
1951 MG TD
Old 11-22-2015, 10:00 PM   #184
joedoh
joedoh's Avatar
well in this case I have never had the shop! we moved in and there was stuff, remodeled and more stuff. daughters truck she never wants to work on and more stuff. I put my foot down and my a$$ in gear and cleaned it all. now everything rolls so if I need space, I kick it out the door!
got my wheel dollies back, I was using two of them to hold the 4.3/4l60e. I bought this cart months ago for just this purpose and finally got around to popping it on there. It rolls so gently that I have to be careful not to park it on the outside half of the garage, there is a gentle slope to allow water to run out the door and the cart just starts rolling by itself!
built a one man lifting frame for my engine hoist. almost ran to get a center bolt and found an eye bolt long enough. waste not want not!
my one man setup was one man short. The front wouldnt balance to lift, I didnt really expect it to, but figured I could lift it slightly with the 2x6 and pull the cab singly. nope. so tomorrow I will pull the front clip I GUESS. wasnt looking forward to all new bolts but cest la vie.
I have my super fancy 50s bomb cart set up for the cab, it has 4 1800£ (yes I know, lb, right yoshi?) wheels with shocks so I think it will hold a cab
imminent progress, the garage is waiting for rolling parts of the truck and I just filled my welding bottle! Short work week, thanksgiving and all, but I should make good progress.
Old 11-22-2015, 10:06 PM   #185
99 to Life
99 to Life's Avatar
like the dollies, luv that patina, should be a nice truck.
Old 11-22-2015, 11:01 PM   #186
Can't wait to see you going on this one!
Old 11-23-2015, 01:01 AM   #187
iowaboynca
iowaboynca's Avatar
Feels good to have an organized garage/shop. Nice work. Like the carts.
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 11-24-2015, 05:25 AM   #188
lower50's
lower50's's Avatar
Bomb cart cool
1951 MG TD
Old 11-24-2015, 05:47 PM   #189
joedoh
joedoh's Avatar
I didnt get to work on the 49 yesterday, I hauled the 248 gmc to a guy 100 miles away for not much more than scrap and gas. still worth it to see it used.
I used to be more optimistic. I would spray down rusted fasteners with acetone and tranny fluid or penetrol days before trying to loosen them. I have learned, that is a lot of work for fasteners I will never reuse. now I either hit em with the grinder/cutoff wheel or just get on both sides of the fastener and TIGHTEN. They give up immediately, its super fast.
so today the front end came loose in about 30 minutes
everything goes in for the thanksgiving day party, but it all rolls now.
Old 11-24-2015, 06:02 PM   #190
69CST-V
69CST-V's Avatar
Sorry I'm late....sub'd
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 11-24-2015, 07:46 PM   #191
Well you got it apart and inside. Nice progress.
Old 11-24-2015, 10:43 PM   #192
99 to Life
99 to Life's Avatar
that's cool the 248 is going to a new home.
Old 11-25-2015, 08:23 AM   #193
joedoh
joedoh's Avatar
he caught me right, I wanted it out of the driveway before thanksgiving so it wouldnt look like a salvage yard. it is usually filled with "treasures" and parts I will use "tomorrow"
Old 11-26-2015, 12:07 AM   #194
lower50's
lower50's's Avatar
Ah yes the I'll use that some day excuse. I think we all use it to much.
1951 MG TD
Old 11-26-2015, 09:23 AM   #195
joedoh
joedoh's Avatar
well, we had the choice when moving, lots of pretty and done tract homes with pretty cul de sacs and HOA, or this house nearly at the end of a dead end street, which hadnt been updated since 1950 (the year it was built), and has a 200ft long driveway. I figure the only thing I really lost was the finished walkout basement but gained ALLL the storage space. took a lot of remodeling though, would have liked to have spent THAT money on some trucks and parts.
Old 11-26-2015, 11:17 AM   #196
Advanced Design
Advanced Design's Avatar
I would choose the house with the 200 foot driveway too! Wow, that cab looks really solid.
Advanced Design is offline   Reply With Quote
Old 11-26-2015, 11:28 PM   #197
youngrodder
youngrodder's Avatar
Nice progress. It always feels good to get something done no matter the size or complexity of the task.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 12-03-2015, 07:00 PM   #198
joedoh
joedoh's Avatar
no progress, my oldest flew in from phoenix for the holiday and the middle girl is in israel/bahamas for her senior trip, so busy busy.
I did get a deal on some 2.5" extended upper control arms, so instead of using the ART tubular arms I have here I will just extend the stock lowers and plate them for bags. They have the spherical upper ball joints and machined cross shafts, so thats nice.
Old 12-04-2015, 01:09 AM   #199
99 to Life
99 to Life's Avatar
those look nice, only company I know that makes flat arms is MMW, are yours from them?
Old 12-04-2015, 04:54 PM   #200
joedoh
joedoh's Avatar
yes, they are also the only company that makes extended arms.
