![]() ![]() Join Date: Feb 2009
Door panels removed, observations and as usual, question or two
71 Chevy Deluxe
Appreciate the help I received earlier. That common "fork" tool for handle/crank removal makes it a breeze. Can't say I'm disappointed with the condition of the panels nor the trim they insert into. Nope, not one bit. Of course the paper "chrome" is flaking off, which surrounds the wood grain..........So that brings me to my first question, what are some good ideas for how to deal with this? There's just one 1" tear on the bottom edge of the LH panel. I figure any black sealant will do. Suggestions appreciated. The second image of the LH door shows a foam rubber seal for behind the door panel. It's not on the RH door and go figure, the LH panel isn't quite as flat as the RH panel. What's the deal with the seal on the LH door, but not the RH door? The LH panel may have been removed once before, because it's missing two washers for the screws for the bottom of the panel. Missing hardware appears to be a common theme on the interior of this truck. Thank you. ![]() ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-15-2015 at 12:30 AM. |
Re: Door panels removed, observations and as usual, question or two
I recently removed both of my '70 C10 door panels and both sides had the foam strip seals. Both sides of my panels were pretty well disintegrated, so I purchased replacement foam tape from my local O'Reilly's auto parts store. I was never really sure of the exact purpose of the seals????? Anyone know their purpose?
1970 C-10 CST, LWB, 402/400, A/C |
#3 | |
And go figure I only have one. That's consistent with what I've found on the interior of this truck. On the good side, they sure built a nice interior for these trucks. My visors, arm rests, dash pad etc., 45 years later and still like new. Let me take a stab at my first question (bump too). There's a "chrome" paint you can use on the plastic. With a good eye and brush, and a steady hand, they can look good as new.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-14-2015 at 07:54 PM. |
Am I missing something or is there no easy way to get behind the inner door panel? I bet reinforcements for the sport mirrors etc. are a real treat.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Hahaha yes they are! I had to get creative and do it solo. I was able to do it by being on the inside of the door with my right arm in the door and my left arm through the vent window lining it up and turning the screwdriver.
Ha, that's what a wife is for. Congrats on the accomplishment. No way I try it alone.
![]() Join Date: May 2014
I didn't know about the plates to mount the mirrors. So used real big fender washers and a nut on each bolt. Talk about difficult!!! The plates would've been a breeze. But yeah the inside of these doors can be challenging to work on. Oh and while you're in there take a good magnet and collect all the rust that's probably laying in the bottom of the doors.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
#8 | |
I can't wait to see what "treasure" is under the seat, mat and gas tank. Hoping to at least locate the spring clips for the bench tracks.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-14-2015 at 09:48 PM. |
#9 | |
![]() Join Date: May 2010
Your panels look great! Two constructive comments... These were designed as "wet doors". I think the purpose of that seal is to prevent water intrusion into the cab. Regarding the silver trim... there was a thread a year or 2 ago regarding a good repair. I'm not sure who posted it, but it may have been davepl. Maybe there's something in his build thread or you could PM him. In the meantime I'll see if I can find it. Jim |
#10 | |
If "you" think about it, that seal could be: 1. air/noise reduction. 2. water intrusion as you say. 3. protect the panel. Where the heck is the Special K, Custom 10, SSTim, Grumpy types?.........Bet we'd get some confirmation.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-14-2015 at 11:23 PM. |
![]() Join Date: Feb 2015
On the plastic chrome around the woodgrain on the door panel: Hobby Lobby or other craft stores sell chrome mylar in different size rolls. I haven't tried it but read about it on this forum and in fact, I'm going to Hobby Lobby tomorrow to look for some. It can be bought online also and comes in different widths.
Tim Yesterday is history, tomorrow is a mystery, today is a gift, that's why it's called "the present". 1971 ![]() |
Very interesting Tim, but not funny..........Sorry, just showing my age. I think I've read that before. Thanks.
Say, check this out. Plug "chrome mylar" into Ebay search. Very nice.
#13 | |
Also on ebay or google it: chrome detailing foil tape
#14 | |
You got that right. I had a Lemon Peeler. My brother had a Pea Picker. Seats were different on the krates, but still vintage Schwinn. Thanks for info.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-14-2015 at 11:59 PM. |
#15 | |
#16 |
Below is a link to davepl's thread (with pictures that look great) about the chrome repair. AND, it is Mylar tape as stated by NTIMID8R.
http://67-72chevytrucks.com/vboard/s...me+restoration |
#17 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-15-2015 at 12:24 AM. |
