11-14-2015, 10:28 AM | #26 |
Re: Taillight harness retainers/routing
First owner, where did you get your wiring? Plugs gave it away. Your clips look to be black rubber coated. Mine are tan, but they're otherwise the same. Turns out I have a hand full of black ones as well. Don't know what they're for, but I suspect they came off with the engine in 1993. I failed to take note.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
11-14-2015, 11:08 AM | #27 | |
11-14-2015, 10:16 PM | #28 |
The plugs on the rear of my 1971 look nothing like what you have in your 9th image. Yours appears to be plastic to metal. My plugs are rubber. What year is your truck? Ooooooops, I'm guessing 1969. ha!..........There must have been a variance between years.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-14-2015 at 10:21 PM. |
11-14-2015, 10:50 PM | #29 | |
69 is a good guess on your part. |
11-14-2015, 10:57 PM | #30 |
I'm just real slow is all. Man you cleaned those up nicely. One side appears aluminum. That 10th picture is of the license plate plug right? Mine hasn't been hooked up in a long while.
11-15-2015, 12:42 AM | #31 |
