Closed Thread
Old 11-15-2015, 06:57 PM   #2876
wreckedchevy
wreckedchevy's Avatar
Re: What did you do to your truck today? Chapter II
1969 Chevy C10 2wd stepside longbox
wreckedchevy is offline
Old 11-15-2015, 09:32 PM   #2877
In The Ten Ring
Originally Posted by wreckedchevy View Post
Um, why did you weld angle to the top of your hood?
In The Ten Ring is offline
Old 11-15-2015, 09:33 PM   #2878
In The Ten Ring
I clear coated my inner grill today. It's not perfect, but considering what I had to paint it with (spray paint) and how bad it looked "before," I am happy.
I had a few runs.....I think once I get the NOS emblem on and polished outer grill, also the grill guard, no one will notice.
Old 11-15-2015, 09:42 PM   #2879
EARNHARDT#3
EARNHARDT#3's Avatar
This weekend I installed the following items on my truck: flex plate, powerglide transmission, tubular crossmember, driveshaft, rear shocks, lokar floor shifter, starter, trans cooler lines, lots of other small things associated with my automatic swap. Got it to the point where I could fire it up and get it topped off with ATF. What's left? New exhaust to be put on, longer speedo cable, remove clutch pedal, put new shift boot on when it comes.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline
Old 11-15-2015, 09:49 PM   #2880
Synestran
I rebuilt the carb, changed spark plug wires and spark plugs, new vacuum advance, adjusted the timing a little bit and then drove it around the neighborhood a couple of times to make sure she is running properly. Still not 100% perfect, but enough to drive without any worries.
Synestran is offline
Old 11-15-2015, 09:59 PM   #2881
72c105speed
Today I removed more interior parts, radio, climate control etc. unbolted the bed and got rid of extra wiring... Need a few extra hands to pull it off
72c105speed is offline
Old 11-15-2015, 09:59 PM   #2882
jdalexa84
I started on the install of a used gear set. I think my pinion might be in to deep but not real certain. Got to dark to mess around with it. This is my first differential setup. Backlash was easy enough to set, I have it at .007 and pinion preload at 16 in/lbs
jdalexa84 is offline
Old 11-15-2015, 09:59 PM   #2883
wreckedchevy
It seemed like a good idea at the time
Old 11-15-2015, 10:56 PM   #2884
midniteblues
midniteblues's Avatar
Pulled mine outside and listened too the exhaust and let it warm up a lil'. Sounds great. It's a lil' loud for my likeing. But it's ok.
I still need to make the exshaut tips.
The kid an I both have dual snorkel z28 air cleaners.
His was a $5.jy find that I gave him,
and mine was a $25.swap meet find. Except I didn't get a lid. So I reused my other lid.
I plan on removing the useless stuff on mine and blasting and paint but it's ok for now.
The kid is good with his the way it is only he wants to get rid of the 5.0.
I so I took both and swapped snorkels.
His now has two straight snorkels.
And mine has two angled snorkels.
Looks much better.
Here's some b4 and after pics.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline
Old 11-15-2015, 11:27 PM   #2885
midniteblues
I forgot to include a few "outside" pics.
We all like pics.
And one at the end of the nite changing oil on the kids truck.
I thought this pic was pretty cool looking with 2 67's in the garage.
Old 11-15-2015, 11:59 PM   #2886
Lancialonnie
Talking Re: What did you do to your truck today? Chapter II
Name:  New paint.jpg
Name:  Body color bed liner.jpg
I finally figured out how to attach pics again, I'm not much of a computer guy.
So after 4 months at the paint shop it is finally getting close. This is the first tinted bed liner this shop has done and I love the way it turned out! The under bed gas tank was installed Friday and it is finally moving on its own again. The paint shop hopes to reassemble the rest and do some touch up this week and then I can bring it home and install all the goodies the UPS driver has been dropping off at the house!
Lancialonnie is offline
Old 11-16-2015, 12:06 AM   #2887
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
We all like pics.
Pretty cool? Are you kidding? Incredibly cool.
Hope you don't mind my taking a few (tiny) liberties with your beautiful shot.
And then using it for my computer wallpaper.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 11-16-2015, 12:08 AM   #2888
gmebey
I check off one more task in this long project..... Replaced a shot distributor!
gmebey is offline
Old 11-16-2015, 01:22 AM   #2889
88Stanger
88Stanger's Avatar
lets see, made a custom alt. bracket since i have tall custom aluminum valve covers. Then i started the fill in the fan hole and wire junction box on the firewall, and start work on the rebuilding of the gauge cluster to white faced gauges with red leds for standard background along with amber, green and blue for standard color replacement.
88Stanger is offline
Old 11-16-2015, 08:57 AM   #2890
Mator
Mator's Avatar
Originally Posted by 9teen69 View Post
Installed new steering wheel and cowl to hood seal.
Where did you get the hood to cowl seal. I cant seem to get mine to lay down and it keep keeps the hood lines out of place.
Mator is offline
Old 11-16-2015, 11:07 AM   #2891
73737373
Buff (Wizard products) and wax; over and over and over. Took the cowl off and buffed/waxed all of that area, including the windshield wiper arms on Sat. Was kind of cool and damp here (OK) on Sunday, so started a fire in the barn and sat there and worked the actual cowl in a nice warm and dry place. Paint is awfully thin in some spots, but where there's paint, it looks great. Straightened out a couple of the lower bedside trim pieces and attached new woodgrain tape. Took off Sierra Grande emblem and used Barkeeper's Friend and a toothbrush and got 45 years of crud off of it; looks brand new. Lots and lots of time and detail work, but much cheaper than hiring a painter and/or buying new chrome and emblems. And put on my new whitewalls, factory steelies and PO1 hubcaps (not the full wheel cover)...Sweet. Yeah, I know, everyone wants a pic....... These are the before.......
73737373 is offline
Old 11-16-2015, 04:14 PM   #2892
eric67c10
Installed stereo and a ground strap
eric67c10 is offline
Old 11-16-2015, 04:19 PM   #2893
tommy3horse
tommy3horse's Avatar
Got a small load of firewood cut. Had to climb a hill with terraces on gravel, she did great.
1972 GMC C1500 350/350
1965 Mustang 2+2 289 4spd, show-car
1965 Mustang Coupe 289 4spd, stoplight racer
1/2 dozen Wheelhorse Tractors
tommy3horse is offline
Old 11-17-2015, 11:20 AM   #2894
powerhaulic
powerhaulic's Avatar
Put mine in storage for the winter
2011 Yukon XL Denali
1994 GMC Suburban 2500 454
1971 Cheyenne Super SB
1966 ElCamino
powerhaulic is offline
Old 11-17-2015, 06:45 PM   #2895
Sicklajoie
The Niner
Sicklajoie's Avatar
Ditched bed cover and took out lifting blocks in rear. Back to stock height all the way around. Next week it'll be in paint jail to repaint inside of bed and bedcaps.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline
Old 11-17-2015, 08:18 PM   #2896
Steeveedee
Who Changed This?
Steeveedee's Avatar
Properly wired up the HEI and removed a bunch of wires that started somewhere and ended nowhere. Fortunately none of them had power. It used to be my FIL's truck, and he did all kinds of strange stuff to it. It's getting new shoes tomorrow.
~Steven
Simi Valley, CA
Steeveedee is offline
Old 11-17-2015, 08:29 PM   #2897
9teen69
9teen69's Avatar
Rebuilt my column...a couple weeks ago
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline
Old 11-17-2015, 09:43 PM   #2898
74baggedbug
Got the 3rd billet knob in the mail today.. May sound cheesy but I had my 3 kids names put on them so they know they are also apart of the truck
74baggedbug is offline
Old 11-18-2015, 12:08 PM   #2899
5567Cruiser
5567Cruiser's Avatar
Insanely pretty!
Ned, Nice look, I did the same thing after trying to polish the original emblems just don't look good with fresh paint. I did the same with the hood emblems after spending many hours trying to polish the originals, I guess the 49 years of exposure to the elements did a number on them.
GARY
67 LWB CST FLEET
56 CHEV 3100
55 CHEV BEL AIR 2DR SEDAN
67 BUICK GS400 CONVERT
5567Cruiser is offline
Old 11-18-2015, 05:55 PM   #2900
9teen69
9teen69's Avatar
From classic industries, lays down perfect and has the correct holes and ridges.
9teen69 is offline
Closed Thread
