Old 11-17-2015, 07:38 PM   #1
tim21391
tim21391's Avatar
1972 th400 speedo error, help?
Been awhile since I been on here but you always help so if anyone has input that would be great... I have a 72 c10 with 402 engine and a turbo 400 trans... Speedo used to work then the speedo gear housing broke so I ziptied it up to get it to work now it don't work again and I think I may of last some gizmos and gadgets.. Tires are 31x10.50r15 I believe.. And gear ratio is 3:08. I know that's how you change speedo but here's a pic of what I have its off google but I would need the housing, the driven and drive gear and all
tim21391 is offline   Reply With Quote
Old 11-17-2015, 07:42 PM   #2
tim21391
tim21391's Avatar
Old 11-17-2015, 07:43 PM   #3
tim21391
tim21391's Avatar
Old 11-17-2015, 07:45 PM   #4
tim21391
tim21391's Avatar
Re: 1972 th400 speedo error, help?
Also, I have no dash lights. And only gauge that works is my oil pressure due to it being fluid driven I know.. And speedo is not working due to the issue listed above... I'm thinking I need to order a printed circuit board for the cluster since its original that's 40 some years old.. Am I correct? All the bulbs looks good just missing one bulb and one holder for it... Thoughts???
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
Old 11-17-2015, 08:22 PM   #5
70STOVEBOLT
70STOVEBOLT's Avatar
I may be able to come up with that adapter. i will check tomorrow and let you know.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 11-17-2015, 08:28 PM   #6
68350
68350's Avatar
I just bought drive and driven gears off of eBay for my th400. You can get the housing too on there. There's plenty of online calculators that'll get you close on the number of teeth you need.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 11-17-2015, 09:22 PM   #7
hamjet
hamjet's Avatar
http://www.transmissioncenter.net/sp...n_______va.htm Go down the page a little ways, they sell them if the boys can't help you out...
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 11-18-2015, 09:02 AM   #8
70STOVEBOLT
Looks like to find out what driven gear you need, you will need to know what drive gear you have, and also the number of revolutions the speedo cable must turn to register one mile on the odometer.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 12-03-2015, 10:40 AM   #9
70STOVEBOLT
Tim, did you try connecting the speedo cable directly to the transmission? Try that and see if the speedometer works at all. If so, get a free gps speed app for your phone and see how far off it is. You may not need the adapter. When I bought my TH400 it had an adapter on it that was broken. I did not use it when I put the transmission in, and my speedo is slow by 3 mph per a gps app that I have on my phone. I have 3.73 gears though.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 12-03-2015, 11:35 AM   #10
kwmech
There are also going to be numbers on the side of the adapter that give the ratio percentage difference
Old 12-04-2015, 12:36 AM   #11
tim21391
tim21391's Avatar
Never knew any of that!! Thanks guys will do that this weekend!!! You guys are awesome thanks again y'all, I knew I could always get info here
Old 12-07-2015, 11:24 PM   #12
tim21391
tim21391's Avatar
Got it all fixed
