Old 11-18-2015, 03:58 PM   #1
tucker69
tucker69's Avatar
cab, bed & core support mounts
I have tried searching for my answer for 2 days. Now keep in mind I am not the sharpest knife in the drawer when it comes to computers. here's my problem, I purchased part#GMK-4143392691S FRAME MOUNT KIT FROM GOODMARK, THIS IS THE 82PC. MOUNT, WASHER BOLT, KIT.
THERE IS NO DIRECTION/SPEC SHEET IN BOX, I CALLED GOODMARK, THEY SIAD THEY DON'T HAVE INFO AS TO WHICH MOUNT GOES WHERE. THEY SAID I SHOULD BUY A "SERVICE MANUAL". I HAVE A SERVICE MANUAL I PURCHASED FROM THIS SITE, HOWEVER ALL THE PAGES ARE SO COPIED/BLURRED THAT I CAN'T MAKEOUT WHICH MOUNT GOES WHERE. MOST OF ALL THE RUBBER WAS GONE ON DISASSEMBLY. SO WHAT I NEED HELP WITHIS, WHERE DOES BUSHING/MOUNTS AND WASHERS GO IN THE ABOVE KIT? IF NEEDED I CAN TAKE PICTURES OF MY MOUNTS...THANKS FOR ANY HELP.
tucker69 is offline   Reply With Quote
Old 11-18-2015, 04:35 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: cab, bed & core support mounts
Here you go this should help .
http://67-72chevytrucks.com/vboard/s....php?p=7362578
Old 11-18-2015, 04:52 PM   #3
toolboxchev
Grumpy and all the other folks here are very helpful, some of that stuff you can buy at the everyday stores.
Let me look a little further...
Also from what I remember there are two different kits, 3/4 and 1/2 ton. The mounts on the frame and or bushings may be different.
toolboxchev is offline   Reply With Quote
Old 11-18-2015, 05:37 PM   #4
tucker69
tucker69's Avatar
Thanks Grumpy, you are a life saver. That was exactly what I was looking for. As I have said before " I am a 98 year old, trapped in a 48 year old body...I would rather sit in a dentist chair for a dual root canal while some Japanese ninja pushes bamboo slits up my finger nails than get on a computer...I realize I am in the minority here...I realize than when everything goes right..(i.e. computer, modem, connections, internet, phone lines, etc) it is so much easier and more informative than picking up the phone or going to the library. BUT...BUT...BUT, its never that easy when I am doing it.. anyway, thank for your assistance
Old 11-18-2015, 05:52 PM   #5
Grumpy old man
Remember when you could walk into an auto parts shop (they weren't called stores) and the guy behind the counter not only knew what part you needed he also knew where it was in his shop and how to install it correctly . and most of them carried S&K tools to do the job .Not Chinese CR@p ! NO computer required !
Old 11-18-2015, 06:06 PM   #6
toolboxchev
AMEN!
Blessed are those that know the truth!
Old 11-18-2015, 08:06 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I miss the big long bunch of parts books and catalogs that were bound together behind the counter. The good old days...
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 11-19-2015, 12:21 AM   #8
Blown06
Blown06's Avatar
Gary
I've spent a lot of hours on a stool at a parts counter having parts looked up. In some ways I miss it but it's sure hard to beat ordering parts late at night from the recliner and tablet.
Me: Jarrod
My project: http://www.67-72chevytrucks.com/vboa...d.php?t=646563
Blown06 is offline   Reply With Quote
Old 11-19-2015, 01:17 AM   #9
Clavo106
I own over 300+ manuals and parts manuals douse it take up room.yes! and do i look at them no not really.. and do I have one for a 67 -72 c10 no I do not! is it convenient no but its shure nice to know I have them.. pros and cons.
Clavo106 is offline   Reply With Quote
Old 11-19-2015, 01:42 PM   #10
tucker69
tucker69's Avatar
alright guys maybe I was wrong when I said I was in the minority.... I miss the "good ole days"..thanks everyone
Old 11-19-2015, 02:31 PM   #11
mmiddle
mmiddle's Avatar
Tucker: save all of your old washers and spacers... you may need them to get everything to line up correctly.
Grumpy: You beat me to my own post... thank you. I spent several hours searching for that stupid picture last month
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 11-20-2015, 10:37 AM   #12
Grumpy old man
Hey , I book marked it a while back . I've worked on hundreds of these trucks and build my own now and I can't remember everything and have to look things up again myself and when you find good info you keep it .
Old 11-20-2015, 11:00 AM   #13
mmiddle
mmiddle's Avatar
Stuff like this I print it out and file it in the "Specs and other info" file. I'm like you, I know a lot but can't remember it all.
Mark
Jesus is the Way!
