11-19-2015, 09:09 AM | #1 |
Is there a trim piece that goes under rear window?
1979 Silverado, is there a trim piece that mounts under the rear window, the length of the window?
I noticed some screw holes under the rear window and it looks like a trim piece should be there. |
11-19-2015, 10:23 AM | #2 |
Re: Is there a trim piece that goes under rear window?
I have a 76 and there is a cab trim piece. There should be corner trim pieces to.
TJ 76 gmc 1500 swb patina finish Dropped 4/5, 350/4 speed 80 Chevy c10 lwb 305/350 |
11-19-2015, 02:02 PM | #3 |
There was optional trim that was about 4" wide that included the cab corners.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
11-19-2015, 02:05 PM | #4 |
yeller
Are you referring to the INSIDE of the cab, or OUTSIDE. If inside...from the factory NO...but there were several companies who made storage organizers, some fabric, some solid, some that required drilling into the metal below the rear window to install.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
11-19-2015, 02:42 PM | #5 |
Im referring to the inside of the rear window.
I have the corners that the seat belt pivot goes through. |
11-19-2015, 05:09 PM | #6 |
No there's no other trim that goes behind the bench. You've got the trim on top of the window and around the seat belts that's it.
85' GMC Sierra Classic Built 350; Weiand intake, Holley 600, Thumpr Cam Built 350 turbo with shift kit & 2500 Stall Thumpin' away |
11-19-2015, 11:56 PM | #7 |
Is it possible, that this was a factory bucket seat truck and someone put a bench in? I have seen it done
11-20-2015, 12:00 AM | #8 |
11-20-2015, 12:45 AM | #9 |
Probably had some cool period correct curtains in it at one time.
Born and proudly residing in a Red State ! |
11-20-2015, 09:19 AM | #10 |
or a sweet gun rack...lol ahh the good ol' days
