Old 11-19-2015, 08:11 PM   #1
donandal
LS exhaust (ing)
I've spent the last week reading up on exhaust systems.
I need to build one for my 53 AD with a GM 5.3 connect
and cruise E Rod setup.
My setup included GM manifolds and CAT converters, so
I need to build the rest to the back. it's 2 1/2" leaving
the converters.
Lots of google time, but it is exhausting trying to find definitive
info about dual vs single systems.
I'm only going to build it once (stainless mandrel bend custom).
I want a nice quiet factory sounding setup.
Too old, don't need the noise.
on the other hand, I don't want to just throw away performance.
Ideas?
donandal is offline   Reply With Quote
Old 11-19-2015, 08:19 PM   #2
bpatrol
Re: LS exhaust (ing)
walker quiet flow mufflers. summit has them
ive used them, quiet but nice sounding .Im getting old my self
bpatrol
bpatrol is offline   Reply With Quote
Old 11-19-2015, 09:45 PM   #3
LeesTruk
I just finished building a system for my 5.3L swap using the Walker Quiet Flow muffler. I built a Y pipe (2.5" in, 3" out) and am just doing a single pipe (3"). I, too, want a nice quiet ride. I should be firing it up within the week, and hopefully can get my son to shoot a video so that you can hear it
Lee
LeesTruk is offline   Reply With Quote
Old 11-19-2015, 10:21 PM   #4
donandal
Lee
yeah
I may go that route also....
single 2 1/2 to 3
hard to decide....
Old 11-19-2015, 11:40 PM   #5
Root2812
Root2812's Avatar
What exhaust manifolds did each of you use? I want to follow along here. I have a 1950 with a 5.3 and I also want a nice stock tone. I kinda like the sound of the stock C5 corvettes but the stock cans are huge on the C5. I am looking forward to seeing what you do.
Oh and I have the exhaust manifolds off a corvette for clearance but I failed to get the down pipe from the manifold when I got them. Will you share where you got the parts to make that piece?
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 11-20-2015, 12:22 AM   #6
Tilt
I talked to a guy just the other day that has a LS swapped 85 swb with 6.0. The trucked sounded just like a Vette. He had dual 3" with x pipe, but had the oval Magnaflow mufflers running sideways with dumps just behind the rear bumper. He said the farther back you can put the mufflers the more it sounds like the newer vehicles instead of an older small block. I'm not real sure how much truth is in that, but his truck sounded good.
'83 Silverado Step Side
'85 GMC short bed.
'86 Chevy Step Side Custom Deluxe
LQ9/4L80 swap (SOLD)
Tilt is offline   Reply With Quote
Old 11-20-2015, 05:30 AM   #7
LeesTruk
I'm using manifolds from a 5.3L Trailblazer (rh) and Buick Rainier (lh). Here's a pic of the Y pipe
My 5.3L came from an '05 Tahoe and included the tops of the original exhaust pipes with the O2 sensors. I just grafted new piping onto the stubs. Got the mandrel tubing from Trubendz Technology (trubendz.com), and had the kits within 2 days of order. You can get either stainless tubing or aluminized steel
Lee
Old 11-20-2015, 01:46 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Cool y pipe Lee. It looks as though the galvanizing/aluminizing on the tube fought your welds a little tho. Removing that coating from the weld area will help a lot, and if it doesn't seem to, I'd suggest ramping your wire speed a bit. It doesn't look like your burning through anywhere, just a few areas that welded cold.
When I built mine, I had issues in a few places despite removing the galv, and found out the major reason was the "oil" coating thats on the inside of the tubes. I got my stock from Columbia River, but it REALLY helps to degrease the inside of the pipes as well.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-20-2015, 04:32 PM   #9
donandal
OK,
I can go two ways.
2 1/2 " pipe with X-Pipe and dual 2 1/2 " mufflers,
or 2 1/2 " inlet with 3" outlet Y-pipe and single 3" muffler.
I have the space for either.
I am wondering if the dual setup would be "too open" and would loose velocity
and whether the 3" single might give better torque?
Wish I knew more about this subject.
Old 12-10-2015, 02:34 AM   #10
americanmusc1e
americanmusc1e's Avatar
Originally Posted by donandal View Post
OK,
I can go two ways.
if you want it fairly quiet, x-pipe and dual 2 1/2 "turbo" mufflers. I've used flowtech raptors before. They are about the quietest muffler that flows well.
here are some sounds on a different vehicle if it helps. https://www.youtube.com/watch?v=Wg3RmMwdYIs
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 12-11-2015, 01:22 PM   #11
slotard
If you can find them and they fit, OEM mufflers off something modern are your best bet for quiet. The cats will quiet you down quite a bit vs catless as well, and between those and cheap take-offs it'll be very quiet and not down much power vs something loud (Chevy doesn't want to lose any efficiency thanks to CAFE).
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 12-11-2015, 03:27 PM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
FWIW, turbo's do count as sound dampening devices....which I find hilarious. Bcuz wastegate dump.
Old 12-11-2015, 08:06 PM   #13
First c10
First c10's Avatar
OK,
I can go two ways.
I went with 2-1/2" into a single 3" muffler Magnaflow. The picture is a little blurry but that is all I have here at work. the truck is not running so I am not sure of how it will sound. I did cam the motor so hopefully it will sound good!!
Good Luck
Scott
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 12-22-2015, 08:04 PM   #14
mattcrp1
mattcrp1's Avatar
Good Luck
Scott
That's pretty much how mine is set up. It sounds good with the little 4.8l.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 12-23-2015, 01:35 PM   #15
First c10
First c10's Avatar
Do you happen to have audio of the sound? Video maybe? I would like to here it as I have not found anyone with this set up to listen to.
GO GO!!!
