printing is my trade
Booster broke any ideas?
My booster broke on install. I pressed the pedal and this thing popped out. Anyone know why?
Also is this fixable or should I just replace it? Thanks for your input!
Jojo's '70 stepside build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=344184 |
laying low
![]() Join Date: Mar 2001
Re: Booster broke any ideas?
Damn son. How big is your foot?
I don't think I've seen that happen before. Is that an imported booster by chance?
#3 | |
Haha! I pressed the pedal with my hand while working under the dash the master cylinder wasn't hooked up at the time. I'm not sure where it was made. I got it from performance online.
laying low
I'd say hello POL, here I come.
Yeah, thats what I figured. It seems like that piece shouldn't be plastic.
It broke exactly for that reason, no master cylinder attached. There was no restriction of the cylinder bore, brake fluid=pressure, if nothing is there, she'll pop like a bullit
Now on some later boosters I have had the rod slide out and I just put it back in before putting on the M/C of course, but it didnt have any pieces broken. that bakealite piece shouldn't have broken like it did I would call them and see about a return. Did you mash the brake [break in this case]pedal without the M/C attached? That or a bed rod or booster housing or bad bakealite piece would be the only possible causes.
#8 | |
Well, I got another booster from a different manufacturer. And with a little bad luck and in a completely different way, knocked the thing out again. Being and different design, the piece came out with nothing appearantly being broken this time. Can I just push it back in place and trust that it won't come out after assembling everything? It doesn't appear to have anything fastening it in there. Seems weird..
You really ought to install a master cylinder onto the booster before you push the brake pedal again.
