Old 11-20-2015, 04:37 PM   #1
OUbesto
OUbesto's Avatar
New carpet bolt holes
I'm installing new carpeting and wondering if anyone has ideas how to best cut holes in the new carpeting that will line up for seat bracket bolts to go through to floor pan?
1970 C-10 CST, LWB, 402/400, A/C
OUbesto is offline   Reply With Quote
Old 11-20-2015, 04:41 PM   #2
Davidf
Re: New carpet bolt holes
I would stick an awl through the well positioned carpet from below. Then, I would cut a square in the carpet, around the awl, with a razor blade.
Davidf is offline   Reply With Quote
Old 11-20-2015, 05:16 PM   #3
OUbesto
OUbesto's Avatar
How large do you it the square?
Old 11-20-2015, 05:25 PM   #4
dmartin1
dmartin1's Avatar
i did the same thing with a sharpened screwdriver.from below.
works well
i cut a round hole but either way,i cut it large enough to where you have a little movement for adjustment on the carpet(incase somehow you had it over to one side too far) but small enough it can be hidden underneath the seat bracket.
mine were like1/2- 3/4 round holes
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 11-20-2015, 05:58 PM   #5
tommys72
tommys72's Avatar
Pretty much the same as above. I used the point on my test light from the bottom
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 11-20-2015, 07:36 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
4" x 4" for each bolt hole.
j/k
Cut it just large enough for the bolt to go through.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 11-20-2015, 08:02 PM   #7
sameyrasmea72
sameyrasmea72's Avatar
I've always used a redhot awl with no cutting.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 11-20-2015, 08:13 PM   #8
NC_John
NC_John's Avatar
I just did this. Used an awl, no cutting required.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 11-20-2015, 08:18 PM   #9
Grumpy old man
Grumpy old man's Avatar
put the bolts in the holes and cut around them .?
Old 11-20-2015, 08:27 PM   #10
OUbesto
OUbesto's Avatar
Great input. Really like the red hot awl that will burn/melt the backing which hopefully will be just enough to allow the bolt to pass through easily. Good stuff guys...thanks!
Old 11-20-2015, 08:52 PM   #11
asolde
asolde's Avatar
This is what I did. I used a awl to find the hole from underneath then I used a soldering iron from the top and melted the hole in the carpet.
1972 cheverolet K5 CST Blazer
350/auto/AC/PS/PB/Aux Batt
From Medford, Oregon
asolde is offline   Reply With Quote
Old 11-20-2015, 09:15 PM   #12
Jrainman
Jrainman's Avatar
I asked my friend who does upholstery to help install my carpet a few weeks back and he just made a small X cut pattern for each bolt hole.
Jrainman is offline   Reply With Quote
Old 11-20-2015, 09:54 PM   #13
FirstOwner69
FirstOwner69's Avatar
I located the hole locations from below with an awl, marked the locations with chalk then used a 3/4" hole saw IN REVERSE so it didn't pull the carpet "yarn". My carpet is ACC with mass backing. I made something like 24 holes total. That's largely due to the fact that I have buckets and console. No problems.
FirstOwner69 is offline   Reply With Quote
Old 11-21-2015, 12:21 PM   #14
OUbesto
OUbesto's Avatar
@FirstOwner69 - I can't wait until Monday to try the reverse hole saw. Seems way too simple. I'll report back on success.
Old 11-21-2015, 12:27 PM   #15
Grumpy old man
Be careful if you have loop carpet it can snag and will run right across the carpet and there's no fix for that . just use a single edge razor blade after locating the hole as mentioned above you only need a 1/2 inch hole .
Old 11-21-2015, 07:01 PM   #16
franken
I used a harbor freight soldering iron from below to melt through on the Camaro...
Old 11-21-2015, 08:03 PM   #17
FirstOwner69
There's a risk I suppose, but I was able to drill all 24 holes in my ACC 80/20 loop carpet with mass backing without snagging the loops. The key is the reverse rotation and, I suppose, a sharp hole saw. Here's a link to an ACC You Tube video that demos the technique at the 4:45 mark.
https://www.youtube.com/watch?v=Tlqy...layer_embedded
Old 11-21-2015, 08:22 PM   #18
jayoldschool
Moderator
Put bolts in floor with no carpet. Put in carpet. Feel bolts. Cut carpet.
jayoldschool is offline   Reply With Quote
Old 11-21-2015, 09:23 PM   #19
9teen69
9teen69's Avatar
Simply use an inexpensive soldering gun and melt/burn thru from the bottom. Works great.
http://67-72chevytrucks.com/vboard/s....php?p=7089312
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
Old 11-21-2015, 09:28 PM   #20
COLDCUT
COLDCUT's Avatar
Soldering iron is your friend. Read this post - works like a charm!
http://67-72chevytrucks.com/vboard/s...d.php?t=659730
1970 Chevy CST20 - 350/350
COLDCUT is offline   Reply With Quote
Old 11-21-2015, 10:54 PM   #21
FirstOwner69
Although I used the reverse rotation hole saw, I like the soldering iron idea. Has anyone used one with the ACC mass backed carpet?
Old 11-21-2015, 11:04 PM   #22
Grumpy old man
Is there anything wrong with a .20 cent single edge razor blade ? It only takes 5 minutes to bolt in a bench seat .
