Old 11-22-2015, 02:10 PM   #1
Tusky
Tusky's Avatar
Tusky Torquey 383ci LS build.
So I read a lot at work. I came across a old article in a magazine. I think this would tow a car well if this motor was installed in a pickup. Let me hear your opinions. I myself will be duplicating this build.
Starting with a 5.3 iron block stroke to a 383ci motor using a 4 inch crankshaft and the bore was 3.902.
212/218 558/562 on a 115 lsa cam
Truck intake with accufab throttle body
36 lb injectors
317 6.0 truck heads untouched
918 valvesprings
comp lifters and timing chain
Long tube headers
Compression was between 9.5 to 10.0
#results was 455 horsepower and 485 ft lbs of torque. Torque production exceeded 450ft lbs at 3200 to 5300 rpm.
Now let's talk prices. I've added up mostly what this motor costs to builds. It's roughly a 4500 dollar motor setup. That's cheaper than the old traditional 383 ht GMPP offer.
Tusky is offline   Reply With Quote
Old 11-22-2015, 04:02 PM   #2
bbbc10
Diggin The SquareLife
Re: Tusky Torquey 383ci LS build.
Im pretty sure u can get a lq4 or lq9 an have bolts an cam an heads an make that much power for less....thats what I do if it was me I wouldnt bore a 5.3 to tha much
bbbc10 is offline   Reply With Quote
