Moderator
![]() Join Date: Oct 2008
Re: Two Speed Wiper Switch
I'd be unhappy about a "rebuilt" column arriving with dead loose floppy switches. If it's a used column you probably should strip it down and fix the bolts that loosen up in the tilt. Considering the condition of the switches I probably would check while you're down in there fixing them.
How is the dimmer. If that's dead you get to hit all of them... Unless there's something very wrong with the CD4/K34 stalk you can probably use it in a new wiper switch. The Cancel cam is usually not too bad. If you're lucky it's just the cancel springs or the horn ring with the cam profile is worn. It's a pain in the neck to get to but you'll already be there doing the wiper switch. The replacement turnsignal switches have mixed reviews... stiff hazard buttons and loose turnsignal swtiching. If possible I'd keep the original by stuffing $2 in Dorman springs into it. This is a 98 Buick but the broad strokes are the same...
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 11-22-2015 at 09:51 PM. |
| Bookmarks |
