Old 10-15-2015, 05:22 PM   #26
Sicklajoie
The Niner
Sicklajoie's Avatar
Re: Tires For 16.5" Diameter Wheels
Originally Posted by Steeveedee View Post
Looks like Firestone is my only solution. Thanks, all for their input. What concerns me is that I might have to buy new wheels, next time I buy tires for Big Orange. Seems a shame to make it a semi-donk.
If eventually you have to go to different rims, I run F#rd van 16 x 7 rims. They're a dime a dozen you won't even notice the difference.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 10-17-2015, 12:06 AM   #27
Steeveedee
Who Changed This?
Steeveedee's Avatar
Heh, that DID occur to me, because the bolt circle is the same across all manufacturer lines. I'd want wider than 7", though, because this beast is carrying a camper shell and an interior load inside the shell, and has trailer towing duties. I'm going to have to seriously look at this option, especially if the wheels can be gotten cheaply enough. This truck has been in my wife's family since 1973, and a big change like different wheels will unsettle my wife. More white steelies will be no change, as far as she would know. I guess the poverty caps still fit? Looks like it from your picture.
BTW, that is one nice truck!
~Steven
Simi Valley, CA
Old 10-17-2015, 12:21 AM   #28
Layne
I went with the Firestones!
Layne is offline   Reply With Quote
Old 10-17-2015, 08:27 AM   #29
Sicklajoie
The Niner
Sicklajoie's Avatar
Thanks!
Same nubs for the hubcaps. The only thing that's different with the F#rd rims is that they're lug centric vs. hub centric. The wheel opening is bigger than the hub, so the rim is centered on the lugs, not the hub.
If you get Load Range E tires, then 7" rims shouldn't be an issue if you're carrying that much weight back there.
Old 10-17-2015, 09:16 AM   #30
16" LT tires are meant to haul. After all, they are truck tires traditionally made for 3/4t and 1t trucks. They have hauled everything under the sun. You can get them in as high a weight rating as your truck can handle. You'll be fine
Old 10-17-2015, 11:20 AM   #31
factorystock
factorystock's Avatar
Looks absolutely fantastic Layne. I appreciate you putting in that extra effort and going down that road less traveled when in comes to pre '69 C20 trucks. Most will not go that extra mile to run correct hubcaps and the one piece solid 16.5" wheels with clips in these earlier year trucks. IMO, the value and pride of ownership will pay off handsomely. Glad you went with the argent paint wheels also. You now have a time machine. Priceless.
factorystock is offline   Reply With Quote
Old 10-17-2015, 05:38 PM   #32
Layne
Thanks Factory Stock.
I knew from the beginning I wanted a VERY Original look, even when I did not know what THAT was.
Thanks a million to you and some others for sharing information that others have forgot, or don't care about.
I am very happy with the look now, and it is certainly worth the extra effort and expense.
Old 10-17-2015, 05:50 PM   #33
Sicklajoie
The Niner
Sicklajoie's Avatar
I was in the same boat when I got mine. It had a nice set of Alcoa aluminums but they just weren't my style.
Old 10-17-2015, 06:18 PM   #34
72CSCC
That is a beautiful truck. I always wanted Red, Orange, Red/Orange - what ever you want to call it - so bad.
Twenty years ago, however, I bought "Big Green".
To the subject - I will be restoring my truck in the next few years. One thing I bought for my resto - which I want to look very very very stock - was a set of OEM option 16.5 x 9.75 rims. Oops. Great if you are driving on your rims, because there are few tires available. Much _recent_ research as pointed me this way:
http://www.intercotire.com/tires.php?id=17&g=1
The best 33, and pretty aggressive:
http://www.intercotire.com/tires.php?id=11&g=1
Oh yeah. GULP. The prices:
Vortrac: $365/ea
Trxus: $309/ea
So yeah, I got a "steal" (steel?) on these wheels. I emailed Interco the other day and told them if they made the Vortrac in a 33 it would sell like hotcakes. I am dreaming.
Not sure what I am going to do.....I do not want a 4"lift on my truck to fit 35" tire.
72CSCC is offline   Reply With Quote
Old 10-17-2015, 07:56 PM   #35
Layne
That Orange truck is beautiful!
Old 10-17-2015, 08:20 PM   #36
I really appreciate both of these C/20s. I was surprised when Interco came out with the Vortrac, since they've always been the big luggy 4wd tire people. But I'm more surprised they only make the 35s in a 16.5. It would serve them well to produce a 12.50/33, 31/10.50, and/or a 9.50. They aren't your mainstream hi-volume company like BFG and could own the classic 16.5 tire market
Old 11-22-2015, 11:46 PM   #37
Steeveedee
Who Changed This?
Steeveedee's Avatar
I ended up with Firestone 9.50R16.5 tires. I'll get some pics up, once I clean up the wheels from where the weights got relocated. My FIL painted the wheels white last time, and painted the weights while he was at it, instead of removing the weights and then reinstalling them after painting. I can understand that- I wouldn't want to remove the weights and then put them on in the wrong place (though I do know how to mark the tire first)!
~Steven
Simi Valley, CA
Old 11-23-2015, 12:05 AM   #38
jocko
jocko's Avatar
good tire choice
