Old 11-23-2015, 03:59 PM   #1
73737373
Remove Front Cab Bolts
On the cab floor, can't get a cutting wheel in the recess to cut all the way thru the welds w/out touching the sides of the recess and cutting thru them, also. I don't have a cutting torch. This operation is to be performed as routine maintenance to replace worn out cab bushings and not a wholesale tear down/build. The seat is out and I'd like to get it done before I put the seat back in which is currently sitting outside w/rain forecasted for TH here in OK. Thoughts? Is a Dremel stout enough?
Took me 10 minutes per side for the rear ones.
73737373 is offline   Reply With Quote
Old 11-23-2015, 04:04 PM   #2
72c105speed
Re: Remove Front Cab Bolts
Get the good metal blades for a dremel or grind on some scrap metal until your cutoff wheel is smaller.
72c105speed is offline   Reply With Quote
Old 11-23-2015, 04:14 PM   #3
Grumpy old man
Grumpy old man's Avatar
Use a sawzall with some good bi metal blades and cut them from the bottom if they're really stuck . I've removed a few cabs this past week with an electric 1/2 impact on top and vise grips on the bottom .
Old 11-23-2015, 04:35 PM   #4
RenoKeene
Florida Edition
RenoKeene's Avatar
I believe he is referring to the puddle weld on the bolt head in the cab.
Take a decent chisel to it, should pop loose from the floor.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 11-23-2015, 04:42 PM   #5
57taskforce
All about them K’s
57taskforce's Avatar
+1 I used an air hammer and chisel
Tyler
57taskforce is online now   Reply With Quote
Old 11-23-2015, 06:49 PM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
The weld on my DS was so small I was able to actually break it by turning it with a 1/2" drive ratchet. This was an accident, I did the DS first and didn't know about the weld, and just happened to break it loose...
PS was a big puddled turd. I used a hammer and cold chisel and it smacked free in a few minutes.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-23-2015, 08:27 PM   #7
Steven R
can someone post a pic of what your talking about, I am lost, welds on the bolt heads????
Steven R is offline   Reply With Quote
Old 11-23-2015, 09:37 PM   #8
Clavo106
I took a 4 1/2 grinder to most of the bolt.nuts and front clip bolts because they where rusted.. it saved me a lot of time then trying to spend all day removing rust bolts n nuts. then to save a few buck's... for the fronts I did the same thing expt I cut the nut on the bottom of the cab.
Clavo106 is offline   Reply With Quote
Old 11-23-2015, 10:11 PM   #9
57taskforce
All about them K’s
Don't have a pic but on some of the trucks the front cab mount bolt heads are welded from the factory to the dimple in the floor on the inside of the cab. I currently have a parts 72 c/10 that had them welded. My k/20 was not welded.
Edit: snapped this pic of my C/10, if you look close you can see the weld where I'm pointing.
Tyler
Old 11-23-2015, 10:20 PM   #10
Steven R
Ok i got it now, was just curious I have yet to see one that the bolts were welded, always just used a impact to remove the nuts and bolts.
sorry if i got your thread off track.
Old 11-23-2015, 11:10 PM   #11
dfwright
dfwright's Avatar
My 72 had them welded. Very heavily welded, I might add. I used a dremel on mine.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 11-23-2015, 11:50 PM   #12
swamp rat
swamp rat's Avatar
My truck had origional mounts and it didn't ever have the spot welds, guess i was lucky?? it was a pita to break then loose tho....
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-24-2015, 05:20 AM   #13
Grumpy old man
I'm thinking this was done on the later model trucks or just at some assembly plants , I've never seen any welded front cab bolts , But I buy 67's as a rule and most of them come from the southeast ? I have 4 cabs outside right now and not 1 has any welds ?
Old 11-24-2015, 10:26 AM   #14
57taskforce
All about them K’s
I'm thinking certain plants, I've got 2 72s from different plants and only the C/10 was welded.
Tyler
Old 11-24-2015, 10:50 AM   #15
Craftsmen
Mine were welded on my 70, I couldn't under stand why the bolts didn't budge when I tried to remove them. I said to myself, why would these be left hand threads, then I looked closer and noticed the welds. I used my Dremal with a thin cut off wheel and put a cut into the weld and then used my 1/2 " impact with a impact socket and busted them loose from the sheetmetal.
1970 C10 SWB
Craftsmen is offline   Reply With Quote
Old 11-24-2015, 08:53 PM   #16
leftybass209
leftybass209's Avatar
The only thing I can add to this is, like many suggested, I have used the chisel, and it does work well!
Wear some ear pro though, that cab is a little boomy with all that chisel smacking!
leftybass209 is offline   Reply With Quote
Old 11-25-2015, 01:07 AM   #17
67ChevyRedneck
My 67 c10 was built in the st. Louis plant. Both sides had the spot welds. There was like 10 plants... Could have varied plant to plant.
Jesse James
Project "On a Dime"
Old 11-25-2015, 01:53 AM   #18
In The Ten Ring
I used a cutting wheel on my Dremel Tool. Take your time, go slow, and wear a set of safety glasses with a face shield over top. One of my wheels EXPLODED. You can't be safe enough with your eyes.
No reason for any hammers, just cut through the weld, smooth up the area with a grinding stone (the Dremel is made for such small jobs) and go on.
In The Ten Ring is offline   Reply With Quote
Old 11-25-2015, 09:40 AM   #19
73737373
Thank goodness for Sears!! Picked up the Craftsman version of a dremel yesterday and will get after this job this afternoon while its still warm and before the rain/cold comes tomorrow. Got it, ALWAYS wear safety gear; I want to be able to see my grandkids and hear them talk...someday.
Old 11-25-2015, 12:03 PM   #20
In The Ten Ring
Great. Keep us posted on how it goes.
The Dremel Tool and its brethren are important tools that really excel on jobs that are too big to do by hand but too small to do by the more powerful tools like angle grinders and reciprocating saws.
I put in my new cab-to-frame bushings and bolts with my dad and it was a two man job requiring a large box end wrench and a 1/2 inch ratchet. The tack welded bolt was probably done to save labor. I used the kit from Wes at Class Heartbeat.
Here is a diagram of what your new bushings should look like IF that is the route you are going. I went with new rubber as I wanted a softer ride than polyurethane.
If your shims from your truck are too far gone, you can have a machine shop make you up a couple or cut your own. If you have a torch or plasma cutter, it would be a very easy job.
Old 11-25-2015, 12:11 PM   #21
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Mine too... 1972 GMC C1500. I just removed the original cab bolts 2 months ago. No spot welds on the bolt heads.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 11-27-2015, 10:13 AM   #22
73737373
The Dremel worked great, but couldn't get the cab seperated far enough from the frame to slide the new bushing and shims in the front. UGH!!! I have an extra rear cab mount bushing and was able to successfully slide that one in in the front plus reuse the shims (mine had 2), but the bushing that's supposed to go in like in the picture above, simply would no go in. I'm going to loosen the rear mount on the same side and jack up the cab again and see if that works. I need about another 1/8 of an inch of clearance, and even w/that, will still have to hammer in the shim(s). That's as far as I got late Wed afternooon when it was 70 degrees and sunny. Rained yesterday and more of the same for today, Sat and Sunday, so it will sit for a while until the weather warms up.
Old 11-27-2015, 12:01 PM   #23
In The Ten Ring
Glad the Dremel Tool worked.
Here is what I did.
1). Put penetrating oil (ZEP 45, which is much better than PB Blaster) onto the rear cage nuts and front nuts for weeks.
2). I removed all 4 bolts.
3). I removed the bushings also.
4). My cab had rotated a few degrees to the left, which would not allow the bolts to go in.
5). I jacked the cab up on both sides with trolley jacks and wood blocks, putting the blocking under the cab (framing) rails.
6). I used a large welding (screw) clamp to rotate the cab to the right.
7). I reused one rear cab to frame bolt as it has the sharpened point allowing it to hit the rear cage nut easily. *The bolts from Wes at Classic Heartbeat had blunt ends, not the best.
8). I turned one rear bolt (from Wes) on a grinding wheel to a point so it would hit the other cage nut easily.
9). My truck has been "repaired" by metal welded over the cab support framing.....the shims were a tight fight but I got those in. My new shims were from a machine shop and were the size in the diagram above. Everything fit perfectly.
10). I tightened all rear bolts and all front nuts till the bottom washer touched the rubber, then I applied two marks with a sharpie, and turned the bolt or nut 1 more full turn (advice of Wise at Classic Heartbeat).
11). My dad held the heads of the front bolts with a large box ended wrench and I used a 1/2 inch ratchet on the bottom (nut).
Old 11-13-2017, 06:46 PM   #24
RedRider
RedRider's Avatar
Removed my cab bolts yesterday, no spot welds.
FWIW: 1970 C-10 built in Fremont.
1970 C-10 "Old Yeller"
RedRider is offline   Reply With Quote
Old 11-13-2017, 10:42 PM   #25
rsavage
rsavage's Avatar
Removed all the body mount bolts on my 69 Blazer to replace all body mounts this past weekend and finished up today. All were tack welded as they were on my 71 Blazer that I restored 5-6 years ago. The bed bolts are easier to grind the welds away with a 3" air grinder with a cut off wheel in it. The front mounts on the "cab" section are much more difficult as they are recessed deeper. I believe that the bolts were tack welded at the assembly plants so that they didn't push up when the body was set down on the frame.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
