Simple? What's simple?
![]() Join Date: Apr 2007
Re: New project! The "Red Herring"
So I said I wasn't going to have time to get to the shop, and then I found an hour and some change to get out there so here we are!
This one is left over from the weekend, I did the second headlight bucket a little more neatly, this is how the replacements will be done. I am going to end up with a flat sheet metal cover held on by two wing nuts, probably. ![]() You can just see at about 7 o'clock the small recess I filed in the inner bucket to allow the bulb to sit in - there's a small stud on the backside that mounts the reflector in the housing. These headlight buckets have a slightly smaller hole than the later GM ones do. But vastly more important, I did a little more frame trimming and was able to get the grille to fit up! ![]() So I didn't goof up the core support too badly ![]() Just a few shots showing clearance. I actually have a fair amount more space than I expected with my radiator moved 3" forward the way it is. ![]() ![]() ![]() I still have the A/C condenser to wiggle in there, and I'm going to be mounting the horns up here on either side of the radiator (there are four of them ![]() I also need to trim the frame horns a bit more, so I can make some sort of front cross member deal to mount the front bumper to.
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
Part of the reason this wiring is taking so long is it's forcing me to deal with 1,001 little detail items I wasn't really worrying about before, like WHERE AM I GOING TO MOUNT ALL THESE AUXILIARY COMPONENTS??
![]() Anyways, started working on horns, tonight. There's four of them, in total, the other ones are going to be *more or less* mirrored on the other side - they're all different shapes?, but you get the idea. ![]() ![]() I'm also simultaneously working on the ignition supply solenoid, wiper reservoir mounting, and modifying and adjusting things (like my fuse block mount) that I previously thought were set and done ... ![]()
Had a lot of yard work to do yesterday, and spent most of today pulling parts off one of the various other projects I have going around here ... but found a few minutes to work on Red.
Driver's horns mounted up, with grill back on to check clearance ![]() I'm not done integrating all the wiring, but I hopefully should have the front clip fully wired up tomorrow. One more step towards the finish. And of course, gratuitous noises ![]()
Sounds like an electric train horn
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
That's what I was going for ... every truck deserves a proper horn
I love it! Ran a HF air horn on my 68 GMC and would scare the bajesus outta folks!
Brett ![]() 67 Camaro SS: 67 Camaro Build 72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build 72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD YouTube: https://www.youtube.com/@6dee7-7dee2 |
