What are the part no and where can i buy?
hi guys,
anybody can help me where i can buy this hangers and shackles for the front and rear suspension. Pls find the photo as reference. pls also ID the part no and name of the part encircled. aftermarket parts are also welcome specially if they give at least 2.5" lift. thanks P.S. Photos Courtesy of LMC truck. |
![]() Join Date: May 2007
Re: What are the part no and where can i buy?
no one makes factory ones, you either have to find a donor frame or you can get a 4x4 shop to fab some up for you.
DIY4x4 offroaddesign
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Moderator
![]() ![]() Join Date: Aug 2011
I had looked for those as well, in the end I repaired my originals. On my truck the holes for the pins were badly elongated I machined larger holes maintaining the factory center and placed sleeves in them returning them to the original size and location. A competent local machine shop should be able to do this for you.
are you making(converting) to a 4 x 4 or you rebuilding?
ron |
im actually converting to 4x4. i need at least a 2.5 inch lift to fit a 33s to 35s tire. any advise on this. looking for a donor frame is impossible for me since im from the philippines and we dont have that much available later frames that i can use of. really badly need help.
here is one of the best threads around on a 4 x 4 conversion and it utilizes later components from 73-87 and parts are more readily available.
to bad that you are not closer as I have everything to do it ron |
i sent you pm ron.
ron aka padresag where is the build thread you said?
60-66 Nut
You can get just about everything you need here for the front spring hangers and shackles and then a shackle flip for the rear. The one thing missing is the front hanger for the rear spring. You might contact Kert and he may be able to set you up with everything. The '67-'72 components or the later model '73-'87 components can work on the early frame. The 52" springs up front and 56" springs in the rear should get you the lift you need for your tires.
http://diy4x.com/home.php?cat=250
hi captain fab,
thank you for the info you have given me. so all the hangers from the the '67-'72 components or the later model '73-'87 components can work on my 64 c10 frame. thats really a relief. the points that i have to install this shackles and hangers, does my c10 frame have a hole that i can just place the hangers and shackles? By the way the, the project build is intended to make at least a 2.5 inch lift. The leafspring length you mentioned for the rear and back, are they sufficient? The tires i intend to use is 35s. |
